$500 gaming upgrade
kennedy
Gaming
2) What's your budget?
$500 tax and shipping included
3) Which country do you live in?
US. Mahopac, NY
4) What exact parts do you need for that budget?
CPU, mobo, ram, SSD
5) If reusing any parts, what parts will you be reusing?
GPU: EVGA SuperClocked 01G-P4-2652-KR GeForce GTX 650 1GB 128-bit GDDR5 PCI Express 3.0 x16
PSU: CORSAIR TX Series CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Active PFC Compatible with Core i7 Power Supply
Case: Antec 900
6) Will you be overclocking?
No
ASUS VH222H Black 21.5" 5ms HDMI Widescreen (1920 * 1080)
ASAP
9) What features do you need in a motherboard?
Nothing particular
10) Do you already have a legit and reusable/transferable OS key/license?
Windows 7 Professional 64 bit
$181 - Intel Core i5-3470
$65 - MSI B75MA-G45
$48 - Corsair Value Select 8GB DDR3 1333 DIMM
$172 - Samsung 840 Series 250GB SSD
$466 - Subtotal (not including shipping, taxes, or rebates)
I gotta ask: What games are you playing? You'll gain a greater performance boost by picking up a higher end video card that you would from buying an SSD.
Any chance you can wait till the release of Intel's Haswell CPUs in June/July?
I agree with tiraides suggestions above. If you aren't overclocking at all with no intentions for it.
Even if the OP wanted to overclock, his $500 limit plus his desire for an SSD would limit his options.
While the i5-3570K normally costs between $210 and $230 (assuming you can't get the Micro Center in-store special), a good, overclocking Z77 motherboard costs upwards of $100 (with many of our favorites costing well over $150). Plus, DDR3 1600 RAM costs a bit more than DDR3 1333. And we can't forget the cost of a good third-party CPU cooler; the Cooler Master Hyper 212 Plus costs around $30.
In other words, the OP would have to choose between having an SSD or being able to overclock.
