~$500 gaming rig... Dell refurbs?
ku1185
Hi! So I'm looking into getting a cheap gaming rig... preferably for under $500 with everything included sans monitor. I don't have any old parts to reuse (except maybe a crappy case that I can steal from my cousin--Antec Sonata), and considering that I'm probably going to need an OS (I have an extra copy that I might put on another machine), I figured going refurb would be my best bet.
I'm looking to play a few games... namely Left 4 Dead, and maybe Starcraft 2 and Diablo 3 if/when they come out. I'm looking at the Inspiron 53x series, Inspiron 51x series, and the Studio 540's.
So my questions are:
1) What would be the minimum processor that you would get as to not have this be my bottleneck in the future?
2) How difficult is it to find a power supply that I could swap in for a video card? Could I just throw in anything or are there limitations to the size or form?
3) What are the limitations to the video card that I can throw in? And what wattage power supply would I need to upgrade to in order for this to work?
I've read that the Quad Core machines have a slightly higher wattage power supply... enough to support a 9600GT without a PSU upgrade. Would this video card suffice in what I'm looking for?
P.S. I have a 20% off refurb coupon for the inspiron and studio series, so please keep this in mind if you decide to budget this out for me.
Thanks!!!
1) Since Dell systems do not allow for overclocking, bare minimum I'd say would be the 3Ghz dual-core E8400 or the 2.4Ghz quad-core Q6600. I know for a fact that L4D is very CPU heavy since it always hits 100% CPU Usage in my task manager.
2) Dell PCs uses standard ATX plugs, sizes and PSUs nowadays. SO basically just about any PSU should work with a Dell PC, as long as it can fit inside the case.
3) Main limitations is the PSU. And wattage is not the most important factor when looking for a PSU. You also have to factor in amperage on the +12V rail, efficiency, design, etc. We cannot recommend PSUs without knowing what the exact hardware the PC has. Read this PSU FAQ:
http://www.jonnyguru.com/forums/showthread.php?t=1036
But I do not think the PSUs that come with the Inspiron serie are good enough for decent video cards like the 9600GT. However I do know the XPS line of PCs do come with very decent PSUs so if you don't want to swap out the PSU, take a look at the XPS line.
The 9600GT is a good video card for 1440x900 and below. My 8800GT, roughly 10% faster than the 9600GT but no longer sold at a reasonable price, plays L4D just fine at 1440x900. Settings are all maxed.
