I need some help with selecting components for a build for my friends father. He has a bunch of the "trivial" components and we'd like to get as much performance out of his $500 budget as possible. Details with the question list as follows!
Web browsing, Photo download (from SD cards and the like), small bits of photo editing, MAYBE some gaming on a very small monitor if my friend goes over to use it.
Budget is $500 with a little bit of leeway if it will result in a noticeable improvement. Taxes and shipping should be included (newegg does not charge me tax where I live), but may fall under the leeway category I mentioned above.
3) Where do you live?
Rochester, New York (him), Rome, NY (me). I make the trek there every couple weeks so I wont need to ship it to him or anything.
4) What exact parts do you need for that budget? CPU, RAM, case, etc. "Everything" is not a valid answer. Please list out all the parts you'll need.
CPU
Motherboard (Smaller is better, see case)
RAM (4GB minimum)
SSD (Large enough for Win7 and some productivity software)
PSU
Case (Smaller is better)
Memory Card Reader (SD, CF, microSD, ect)
He has a bunch of spare parts that he is going to be using for this build:
6) Will you be overclocking?
No. I do not want to have to support the OC (I live 2 hours away).
I do not know the monitor size. My guess is the upper end being 20" wide screen. More likely sub-20" 4:3 though, from what I saw in his computer room last time I was there.
I will most likely build it myself and purchase the components online.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
If it's possible to fit USB 3.0 into the budget he would like that. He's a bit of a gadget freak and I can see in 5+ years down the road him having something that could make use of it. If that isn't possible, that's perfectly fine as well.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? 32bit or 64bit?
My friend, his father (my "client") and me will be purchasing a copy of the windows 7 home premium 64 bit family pack when that is released. It is my understanding that you can use these keys/cds as fresh install of windows 7 and not just the upgrade. Is this correct?
I will link my first run through of components here, I am well outside the budget (by $100+) with these builds however. Any suggestions as to where to save money without a huge performance hit would be welcome!
CPU: I went for upper mid-range performance for these. They are currently overkill for his intended uses, but he likes to have some power and would enjoy these. Overall, I'd say the CPU category is where I could save the most amount of money with your help.
Intel Core i5-750 Lynnfield 2.66GHz 8MB L3 Cache LGA 1156 95W Quad-Core Processor ($195)
-or-
AMD Phenom II X4 965 Black Edition Deneb 3.4GHz 4 x 512KB L2 Cache 6MB L3 Cache Socket AM3 125W Quad-Core Processor ($166)
Motherboard: If I had to pick a component I sucked at choosing, it'd be motherboards. I could use a lot of help here! I stole the AMD board from a suggestion on another similar build on this forum. I am also looking for a smaller form factor if possible. Mid ATX sized case is ok, but smaller would be better (per his request).
GIGABYTE GA-H55M-S2 LGA 1156 Intel H55 Micro ATX Intel Motherboard ($75)
-or-
MSI 880GM-E41 AM3 AMD 880G HDMI Micro ATX AMD Motherboard ($75)
RAM: As I mentioned above, looking for 4GB minimum and he will not be doing OC. Would DDR3-1066 be too slow or unreliable for this build?
G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Dual Channel Kit Desktop Memory Model ($89)
SSD: This component may be not required. I would very much like to cram one into his budget but if it is not possible then we can toss it out and save the cash. I went with OCZ over Intel because of the cost/GB and the performance difference is not significant enough to warrant the extra cost in this build. 60GB seemed like a good size for a ~30GB (guessing) OS + MSoffice/OpenOffice + misc programs, if I can safely get away with less, do tell!
OCZ Agility 2 OCZSSD2-2AGTE60G 2.5" 60GB SATA II MLC Internal Solid State Drive ($147)
PSU: Shamelessly stolen from another build thread recommendation. Wattage may be overkill for intended use, please advise!
Antec NEO ECO 520C 520W Continuous Power ATX12V v2.3 / EPS12V 80 PLUS Certified Active PFC Power Supply ($60)
Case: As stated above, smaller is a goal of this build (if it does not sacrifice cooling). As such I picked out a mini-tower for Micro ATX motherboards. This case does not come with any fans though, and I may want to buy one just to get some through flow in the case. I picked out the one with a brand name I recognized, so advice is welcome! (If we can find a case with memory card readers included, this is a good thing, the linked case does not have them)
COOLER MASTER Centurion 541 RC-541-SKN1 Black Aluminum bezel, SECC chassis MicroATX Mini Tower Computer Case ($50)
Memory Card Reader: Required item, Compact flash, SD, and microSD are all required inputs. If we can find a case with this included, all the better.
Rosewill RCR-IC002 74-in-1 USB 2.0 3.5" Internal Card Reader w/ USB port / Extra silver face plate ($16)
Overall cost with Intel CPU: $631 + $9.99 shipping
Overall cost with AMD CPU: $602 + $9.99 shipping
As you can see, over budget. I could use some help trimming out the fat!
CPU
RAM (4GB minimum)
PSU
- 500GB hard drive of some sort, I don't know many details other than it is SATA compatible.
- DVD/CD reader, again, don't know any details. I need to make sure with him that it is SATA compatible.
- Nvidia 8600 GTS that my friend gave him after upgrading to a GTX460.
-or-
-or-
