$500 build help
pinoy16
1) What will you be doing with this PC?
Light gaming (WOW, SC2 and Rift).
$500-550 after tax and shipping
3) Where do you live?
Raleigh, NC
CPU, Mobo, Ram, HD, DVD burner, PSU, Case, Video Card
Will not be using any previous parts
6) Will you be overclocking?
No
22", 1680x1050
ASAP
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
I don't need any features except for the typical.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Yes, Windows 7 64
I'm mainly confuse on what CPU, Mobo and Video card to get. I haven't built a PC in 2 years and not to sure what AMD/Intel currently offers. Would love to have a quad core if at all possible. From what I have seen, I'm thinking a Phenom II might fit the budget. As far as the video card, a 4850 might be powerful enough since I don't think my resolution will bog it down too much.
So far I've got.
$40 Gskill 4GB
$60 Antec BP550 Plus
$60 Western Digital Caviar Black 640
Thanks for the help guys.
$120 - AMD Phenom II X4 955 Black Edition CPU
$55 - Biostar A880G+ AMD 880G mATX Motherboard
$41 - G.Skill Ripjaw Series F3-10666CL9S-4GBRL 4GB DDR3 1333 RAM
$158 - MSI R6850 Cyclone PE Radeon HD 6850 1GB PCI-E Video Card
$45 - Western Digital WD5000AAKS 500GB 7200RPM SATA 3.0Gb/s Hard Drive
$23 - Samsung SH-S222AB SATA DVD Burner
$64 - Antec NEO ECO 520C 520W PSU
$40 - Thermaltake V4 Black Edition ATX Case (use promo code "EMCKEJG36" to get it to that price)
Total: $546 shipping
Notes:
- The video card and CPU are sale prices that probably only last till midnight tonite. As such, if you can, get the CPU and video card FIRST. Those are really good prices for those two parts. If you had to get them at normal pricing, it would have bumped up the costs by another $50. So definitely get those two parts ASAP especially since Rift and WoW are rather CPU and GPU heavy even at your mid-range resolution
- The WD 500GB drive is actually faster than that WD 640GB drive due to better platter design and density.
- That Antec 550W PSU that you chose is not worth $60. The extra $4 for the ANtec Neo Eco 520C is well worth it due to the sheer difference in quality between the two PSUs.
