<$500 Budget Build
Tunnel Vision
Casual gaming, web browsing, school work, email, ect.
Price needs to be below $500
Pennsylvania, USA
4) What exact parts do you need for that budget? CPU, RAM, case, etc.
Case, Mobo, CPU, GPU, RAM, ODD, HDD, and windows 7 64bit
A power supply will be reused:. Corsair CX400. Also, a 20' monitor will be reused.
6) Will you be overclocking?
No
I'm told the monitor is around 20'. I'm not exactly sure of the resolution.
I plan on building the pc in the next couple weeks
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
No specific features are required
10) Do you already have a legit and reusable/transferable OS key/license?
Nope, I will be buying an OEM copy of Win7 64bit
So far, I have quickly compiled this list of parts:
Case: XCLIO Godspeed 747 -- 29.99 http://www.newegg.com/Product/Product.aspx?Item=N82E16811103035
Motherboard: BIOSTAR N68S3+ AM3 -- 39.99 http://www.newegg.com/Product/Product.aspx?Item=N82E16813138293
CPU: AMD Athlon II X3 450 -- 77.99 http://www.newegg.com/Product/Product.aspx?Item=N82E16819103886
GPU: Galaxy GT 430 -- 54.99 http://www.newegg.com/Product/Product.aspx?Item=N82E16814162067
Memory: Corsair 4GB -- 19.99 http://www.newegg.com/Product/Product.aspx?Item=N82E16820145322
HDD: Seagate 1TB -- 109.99 http://www.newegg.com/Product/Product.aspx?Item=N82E16822148697
ODD: LG -- 15.99 http://www.newegg.com/Product/Product.aspx?Item=N82E16827136240
OS: Windows 7 64 bit -- 99.99
Total: 448.92
I would like you guys to give your recommendations on the entire build, but also specifically on the CPU and Mobo as I have not built many AMD systems yet. Also, I could not find any combo deals on newegg that would work for this build, so if you guys can, that would be greatly appreciated :)
Thank you very much.
That case is OOS. I recommend spending the extra cash for these cases:
$50 - NZXT Source 210 Elite Black ATX Case
$50 - NZXT Source 210 Elite White with Black Front Trim ATX Case
Swap the CPU, mobo, and DVD drive for this Intel setup:
$79 - Intel Pentium G620 CPU + LG Super-Multi DVD Burner Black SATA Model GH22NS90B Combo
$50 - Biostar H61MGC Intel H61 mATX Motherboard
Total: $129 shipped
$5 cheaper than your planned setup but you now get a faster and lower power CPU.
What exactly do you mean by "casual gaming"?
I'm building this pc for my friend's sister. By casual gaming I meant that this pc will not be running games more demanding than world of goo, sims, plants v zombies, or any game of that sort.
In that case, the GT 430 will be fine.
