A friend of mine just called me asking for advice on getting a new PC. His "what are you doing with this PC?" and budget are very similar to this other build below, http://hardforum.com/showthread.php?t=1517150, but with some key differences. BTW, I did one of these threads back in October for my own desktop, got some great guidance/advice, and the PC has worked like a charm with no problems (the video card fan spins loud, but that's it.)
Something to keep in mind is, for his budget, would he be better off getting a pre-built, off-the-shelf computer (especially since he would have to buy a Windows license if building his own)? If so, what brand/model/spec would you recommend?
1) What will you be doing with this PC? Gaming? Photoshop? Web browsing?
General browsing, WoW, Excel, Word
$500-600 including tax and shipping.
3) Where does he live?
Bayonne, NJ (I live in Fair Lawn, NJ)
3A) Do you live near a Microcenter?
Yes. I live very close to one.
4) What exact parts do you need for that budget?
Everything but the monitor - he's going to buy that separately later.
5) If reusing any parts, what parts will you be reusing?
Nothing. Actually, now that I think about it, when I bought my SSD, I accidentally bought 2 from Newegg. I have an Intel X25-M 80GB that's still in the unopened box. I could give it to him, I guess. Or I could sell it at a loss. Would an SSD be worth it in this type of system?
6) Will you be overclocking?
No.
He plans on buying a 24" or 27" monitor.
Within a month.
9) What features do you need in a motherboard?
Nothing out of the ordinary. Maybe USB 3 if the price differential is minimal, but perhaps not even that. I should ask him; I doubt he knows about USB 3.
10) Do you already have a legit and reusable/transferable OS key/license?
No.
I would try to spec out some components on my own, but to be honest I'm not that informed myself - for my own PC I relied on the advice I got here (SSD - good advice!) and comparing to comparable builds/budgets. And while I did build my own PC only a few months ago, unlike my friend I work from home, the PC was a work expense, and I got a much more high-end PC, so I haven't done any research on components in his price range.
Thanks in advance for your help.
No.
Within a month.
No.
