MaloventEvil
- Mar 31, 2010
Hello all,
I have been trying to upgrade my media PC to add a 16x1.5TB Seagates. I added in the drives to my Norco 4020, and plugged them into a Highpoint 3540 raid card... The computer would not post -- the bios would start to post and then it would just reboot before i could get to setup or anything. If i pulled the drives from the hot-swap trays, it would post!
After swapping literally every component on the computer (mobo, ram, cpu, raid card for an Adaptec one, power supply for a 1200w one) the same thing happened (would not post). I then pulled the drives from the hot swap bays and plugged them DIRECTLY into the raid card via a mini-sas -> 4x sas cable and it posted just fine!!
I thought this was a backplane issue, so I tried new Backplanes and a 4220 and the exact same problem persisted!
Has anyone ever heard of this? Any ideas?
If your idea fixes the problem, I will paypal you $5.
Thanks,
-mEvil
extra info:
orig specs:
- intel q6600 cpu
- GIGABYTE GA-EP45-UD3P LGA 775 Intel P45 ATX Intel Motherboard
- 8GB ddr2 ram
- 1000w mushkin power supply
- 9x1TB WD
- 16x1.5TB seagates
- tried swapping the motherboard for another q6600 motherboard (can't remember name), tried swapping power supply & ram
then tried getting a new mobo/cpu/ram per highpoint's recommendations
- i7 860
- asus p55 deluxe
- 8GB ddr3 ram
same issues persist.
Thanks,
-mEvil
extra info:
orig specs:
- intel q6600 cpu
- 8GB ddr2 ram
- 9x1TB WD
- 16x1.5TB seagates
- i7 860
- asus p55 deluxe
- 8GB ddr3 ram
