ChingChang
- Mar 27, 2003
I just got the logitech X-530 speakers. I connected each speaker up correctly to the sub. Then there's three plugs coming from one speaker, that need to connect to the computer (green, black, and orange/yellow). I know the green is for the front two, black is back two, and the yellow is the fifth one.
Well since I made my case out of wood, I can't access the ports on the far right of any cards. I will have to make some modifications to the case when I go back home. I just barely got the coaxial cable onto my tv tuner. Because of this, I could not connect the yellow plug into the sound card. The black and green plugs fit in fine.
I don't mind if the fifth speaker doesn't work for awhile. But I'd like the four others to work.
I'm using a very old sound card - Creative Live! 9000 I think. In the audio options, I went to 'Advanced Speaker settings', and changed the Speaker setup to '5.1 surround sound speakers". Only the front two worked. I also tried the 'Quadraphonic speakers' setup for 4 speakers, but it didn't do anything.
Do you think I need to have the yellow plug connected for more than two speakers to work? or is my sound card fucked
