4pin vs 8pin cpu connector
Does it matter if a mobo only has a 4pin cpu connector? I'm trying to decide between a gigabyte and abit and one has a 4pin and the other 8pin connector. Right now I have a E4400, but in the future I want to get a 45nm quad. Just want to make sure the 4pin will have enough power.
You should be fine.
The 8 pin was originally for dual cpu server boards and EPS server power supplies. People started wanting to use the EPS high wattage supplies on enthusiast boards so vendors started using the 8 pin (which will still take a 4 pin plug) . So it is mostly overkill on our boards. However it does distribute the current through more wire and eliminates any concerns of overheating the 4 pin connector and sometimes, but not always, it might, maybe, you have to check, indicate a beefier cpu voltage regulation/supply circuit on the motherboard. If everything else was equal I would prefer the 8 pin but I would not let it get in the way if one board had another feature I was interested in and the other board did not.
I would be looking at the number of phases the cpu voltage circuity used, the cooling for the mosfets and the general component quality first. But both abit and gigabytes have no issues with quads that I am aware of if the boards support quads I would not worry too awful much about it.
