49 Port USB Hub
Jesus Christ!
One Blackberry, one printer and 47 thumb drives. Yeah I'm gonna get me one ;-)
Now what would be interesting is if this was USB 3.0 and all those slots were filled with 128GB USB 3.0 Flash Drives with software that allows you to create a RAID array.
Did anyone stop to ask "Why?" .. do they plan to replace Ethernet cable protocols with that thing?
They couldn't have rather given this thing a power brick?
Imagine all 49 USB humping dogs all going at it at the same time! thats just Golden
Why? What sort of latency would one have to expect if they were actually using most of those ports?
Is it USB 2.0? I wouldn't want it if it was USB 1.1 or lower. Additionally, all USB 2.0 devices (hosts & clients) are backwards compatible so saying that it supports them is crap.
lol all those ports on just one USB ports for the host? I like the car fuse.
Its for mass programming of flash drives. You fill it up with drives and it appears as one device to the PC. How else would you program thousands of flash drives to hand out/sell?
Oh, I was hoping to use 50 mice at once.
I was thinking that. Maybe a 90w or 120w laptop brick should do the trick.
This thing is capable of drawing almost 25 amps (500ma per port), not counting the hardware inside the thing.. Most laptop bricks only give you 3-5amps.
at ~19v... you could make a 5v 25a brick...some dell USFF machines use a 12v 18a powerbrick... so its definately possible :)
yes, the more current you draw from the adapter, the lower the voltage it supplies. But my 19v 3.42a get pretty damn hot as it is. I can't imagine it having to pull 25a from it, and the efficiency of a linear supply is horrible to begin with.
HP Printer Bricks :p Those will easily supply the amps you need ! I don't have mine anymore but I can recall something like 30amps easy over 24v
This is the version I made a few years back..
3x 7 port hubs electrical taped together :-P
Hm.... I need to find 20 flash drives to try this out.
You'd still get about 20-25MB/sec maximum due to the single port host connection. That's effectively where USB2 tops out at due to overhead. It's pretty sad when you can max out what USB2 is capable of with one eSATA externally connected drive... but hook that same drive up to a PCMCIA/CardBus to eSATA adapter and you can get 2.5x's that. (I get 70MB/sec solid on mine. Maxed out CardBus. Same drive, same enclosure got 23MB/sec maximum over USB2.)
A better way to go if you're gonna raid up a bunch of flash drives. That's ~25MB/sec output times 3. CPU utilization would probably be a royal bitch though.
That's a lot of ports. Never seen or thought of anything like that. It would be hard to get a different device for each one.
I think my Inspiron 9100 power brick could do it lol its huge lol. Not really and i think if they were all under load only a Highend atx power supply would be the safe bet. Depends on what the usb is powering also.
http://www.bigbruin.com/reviews05/thumbraid_5
He was getting 32MB/s reads/writes off a single hub...
http://linuxgazette.net/151/weiner.html
He got 52MB/s reads...
