Radeon HD 4850 and 4870 are 23cm long
http://www.hardware-aktuell.com/view...hp?article=816
Link doesn't work.
Anyway that's 9 inches for those who don't use the metric system.![]()
I have a 4850 in a SOLO and the only problem is that the PCI-E power plug goes into the the HDD cage so you will lose the space for a Hard Drive.
Also it *is* possible to design these cards for a shorter PCB. Gigabyte redesigned the PCB of their 8800GT TurboForce, making it significantly shorter than a regular 8800GT (19.5cm instead of 23cm). I guess Nvidia and ATI are too cheap to spend any money making their reference cards more tidy and compact..
Oftentimes shortening the PCB requires layers to be added, which raises the cost by quite a bit. It's not so cut-and-dry as to be able to say "ATI and nVidia should just do this because it's better".
