Yah, I'm starting to look at 30" monitors myself to flex the 4870x2s muscle. Any recommendations?
My leaning right now is this: http://accessories.us.dell.com/sna/...etail.aspx?c=us&l=en&s=dhs&cs=19&sku=223-4890
A little pricey but it seems to get great to excellent reviews, tons of input, and great down scaling.
As I understand it the 3008WFP has tons of input lag. That's what I've heard anyway. I haven't used one myself so take that with a grain of salt.
But the 3008 has an S-IPS panel which is one of the finest of today. AFAIK these shouldn't suffer from input lag like VA/TN-panels. My own dell 2007wfp is a giant leap from any TN-panel I've tested in terms of input lag. The use of overdrive is in those panels bothersome.
You aren't using the speaker bar are you yang88she? That would have to go if I had decided on the Gateway.
Problem is people are comparing the 4870x2 to the gtx280. Which is ok- but when 8800 ultras came out everyone was quick on the gun to talk about pricing:
Well Im looking at NCIX.com right now and 4870x2's go for 615.00 and GTX280 goes for 419.00
Thats a 200 dollar difference.
Anyone care to explain why that doesnt matter now? LOL
It still matters; a single 280 is NOT enough for 2560x1600 gaming so you must buy 2x 280= $838 and maybe change to a SLI MOBO ( that are more than a notch inferior to X48 offers), but a single 4870X2 is enough for 30" owners, and runs in ANY MOBO.
so 4870X2 still cheaper than 280. When you add to it DX10.1 support the equation looks WAY more unbalanced.
No doubt peoeple should go for 4870x2 if they want a single card.
here is a link that shows tri 280 beating dual 4870 x2s
http://www.driverheaven.net/reviews.php?reviewid=609&pageid=1
enjoy.
also they were using some rather old ATi drivers from what I can recall from that article...
either way, those uber systems are beyond sickness...2xqx9770's....jaw drops
Actually that system has dual QX9775's. The QX9770 is an LGA775 processor while the QX9775's are LGA771.
A few things to keep in mind when reading this reading:
4. Total die size -> GTX 280 x 3 = 576 mm^2 x 3 = 1728 mm^2. 4870 X2 x 2 = 256 mm^2 x 4 = 1024 mm^2
Yeah, total die size is definitely at the top of the specs I look at.
didn't even realize they were 771's...wow
The QX9770 and QX9775 are identical in virtually every way except the QX9770 is LGA775 and the QX9775 is LGA771. They have the same amount of cache memory and identical clock speeds and core design. Both are Yorkfield XE processors.
you forgot to mention, costs over 1400+ clams a piece
Last time I checked the QX9770 and the QX9775 cost about the same. Right around $1500 each.
My wife's 30th birthday is coming up, I don't think she will be ok w/ me adding one of those anytime soon
Well the cost break down is even worse for the whole setup. $1500 for each CPU. You'll need two of those. $610 for the motherboard and some Crucial PC2-6400 DDR2 800MHz FB-DIMMs will cost you about $270.00 for 4GB of them. (2x2GB)
I'll leave it to the "motherboard editor" to run and test such a "dream system"
btw Dan, have ordered your 2nd x2 yet? Gonna try some AOC, CSS, maybe some Crysis tonight
