EK demands milimetric precision on install or it will bend the card. a bit more of strenght on the screws and your card will bend like an anaconda, maybe even die. and DD is cheaper.speaking as an EK 4870x2 owner: it is beautiful, but not worth the higher price tag and more delicate instalation.
Please elaborate on the issues surrounding the use of a EK water block with a 4870X2. Thanks.
I'd like to submit the aquagratiX for HD 4870 X2 for consideration. Same price range as the EK, arguably better quality/looks. Didn't buy one yet, but considering to just order it together with a pump directly from aqua.
That is one nice looking block. I wish the spacing on any one of these damn full blocks would fit 1/2" 3/4" BP compression fittings!![]()
I use the same tubing size and planning for a full coverage block as well. You can also get the 45 rotaries from Bitspower for the cover. I think there are also some kind of BP extension that is normally used for Swiftech products (someone correct me if I'm wrong).
I had the DangerDen waterblock on mine. The temp drop is amazing - friggin 85C full-load to 36C full-load, and no noisy fan. /drool The 4870x2 wasn't performing as well as it should in my system for some reason though (there are a bunch of reported cases on the ATI forums about this...never could fix it with any version of the drivers), and the voltage regulator coil (or so Sapphire says) was oscillating like crazy, making really...really...annoying noises whenever certain 3D games were played. I'll be selling my DD waterblock on here...as soon as i get 50 posts, that is. :\ Silly post requirements.
I put zip ties in after I took the pics.![]()
