Infaustium
- Apr 16, 2008
I finally snagged a Sapphire 4870, but I want to make sure of a few things upon receiving/setting it up (especially since my wife will be inheriting my 8800GTX).
Driver: Should I bother installing the driver off the disc, then installing the hotfix over that driver? Or simply install only the hotfix (8.6) driver?
Since I haven't used ATi in years and people have been talking about lack of drivers right now, want to make sure I do this right.
Fan Speed: Right now, the only way to really control the fan speed is creating a profile and editing the XML file of that profile, then loading it every time I boot. Is that correct?
From reading another post about fan speed control, I just wanted to be sure nothing has changed. Loading it every time you boot is a bit of an annoyance, but if that's what we have to do right now, I just wanted to confirm.
Settings: Not sure at all on this... so when setting IQ with the 4870 (or ATi in general), does setting the IQ bar to max effect in-game visuals even if setting AA and AF in-game?
Also, if setting AA or AF in the CCC, do you not set it in-game, as with Nvidia GPUs?
With Nvidia, it's one or the other, set in-game or use the CP. I completely forget what it is with ATi, but I think you at least set the general IQ with the slider bar (like with Nvidia) and just use in-game settings and that'll work fine.
OK, that's it
Thanks in advance for your time and input!
OK, that's it
