Uberbob102000
- Apr 29, 2006
I'm getting a new video card for my secondary rig and I was wondering which card would be better @ 1920x1200 and 2560x1600.
Thank You in advance.
Even if both were $300 that would be still true.
How so? GTX260 runs cooler, sucks less power, and whoops on the 4870 in AoC.
But, you do have to consider price! For a secondary rig, I would most definitely go with a 4870.
It runs cooler because PowerPlay isn't working properly yet. And it only draws less power on idle, again because PowerPlay isn't working yet.
And it beats the 4870 in AoC... which is one game. Have you seen how the 4870 destroys even the GTX280 in some games?
That's because [H], despite how good they are, only tested THREE games.
In any case, I'm thinking about Bioshock where even the 4850 can almost match the GTX280. I've confirmed this with my own testing. For some unknown reason, the 4xxx series is blindingly fast with Bioshock.
Then there's CoD4. Techreport shows that the 4870 matches the GTX280.
The reason why [H] tested those three games is because the games you mentioned above can be maxed out with a 9600GT at 1920x1200. At any rate, all high-performance cards are pulling 100+ FPS at max settings, which is more than plenty. For the new cards, games like Crysis and AoC are what matter. Whether or not we get 100 FPS or 140 FPS matters in CoD4 or Bioshock matters zero.
I mean, I could load up Quake 3 and say, "Oh my gosh! The GTX 280 gets 300 FPS, but the 4870 gets 400 FPS!"
And yet you don't even have to install the CCC at all.
Of course, it only takes 10MB of RAM on my machine and after the first time I've opened it, it takes 1 second to open.
Maybe you're just operating on old information.
According to [H]'s review, the GTX 260 is comparable to the 4870. What RB30 posted above also confirms this. Not seeing how it is destroying the GTX 280 if that's the case.
And don't give me the link to Anandtech's article, because it showed the 3870x2 outperforming like the 8800GTX in that one.
To the OP: For the money, the 4870 is a way better buy than the GTX 260, like others have been saying. The only difference here is that the GTX 260 has more memory and is thus better when you are applying AA in high resolutions. Other than that, it's your call.
The 4870 preforms all most as good and some time better then the 280 and it only a little over $300.00, instead of over $600.00 for the 280. It would be foolish to buy a 280 right now.
AA scaling is better in the 4xxx series though. So if AA were turned on, the 4xxx would have even a better showing.
Most of the Anandtech stuff, he doesn't turn on any AA...I think the GT200 architecture is better "futurized"...as in, it's got more memory basically.
But price/performance the 4850 whoops it up!
Until it runs of memory at high resolutions due to the 512mb. In any case, it was basically the same out of pocket cost for me to stepup to the 260 compared to buying a 4870 and selling my 9800GTX. So i went the easier route and thats stepup.
Huh?
Looking at the [H] review here...in Crysis, GTX260 beats 4870, both are playable. In Assassin's Creed, 4870 beats GTX260, both are playable. In AoC, GTX260 destroys 4870, 4870 is NOT playable with the same settings...draw distances are lower on grass and ground textures, AND 4870 has 2x AA turned OFF!
Huh?
