I'm too lazy to read the rest of the thread but I was curious if you checked if your 4850 PCIe lane is running in 16x?
I was thinking the same.
Double check in bios or gpu-z if its really running at x16.
Second, I stressed that all my stuff was exactly the same, so yes my test was run at 1680x1050. Besides, if i was running a lower resolution my fps should only be much higher then that benchmark.
I would again like to point out that CPU is NOT the issue here. Almost guaranteed. I have played hl2 since day 1. XP 2100, XP 2400, XP 2800, XP 3000, XP 3200, A64 3000, A64 X2 5200, A64 X2 5600. The only thing that ever changed my frame rates were my video cards and video card drivers.
My current setup gets 100+ fps in source games on max settings - not an issue. I would say try reinstalling windows and use the 8.6 + hotfix only.
As a side note, to prove its not the cpu. Gabe Newell - the creator of the source engine - said that HL2 would have 0 issues running on the Wii. Not to mention there was a version for the Xbox (not 360, but the Xbox). Both consoles run around 800 mhrz and are capable of playing the game fine.
EDIT: Thats 100+fps on 1680x1050 res with max settings.
Yea it sounds that windows is FUBARed, if u know some how get a wierd error when trying to install hot fix.
This is what you should do
1.Format , Install windows
2.INstall SYS Drivers, update windows/directx
3.install Vid drivers hot fix only
4.install game
It could also be your running a 32 bit game in 64 bit windows. Try 32 bit vista or xp. Either way, once you screw up the drivers like that its best to reinstall (saves time).
You have any type of antivirus software running in the background? What do you have running in the background, what microsoft patchs do you have?
Did you check to make sure BIOS and chipset are up to date?
Like I said, this is virtually a fresh install of windows, been running it only about 20 days. I don't see how formatting windows would fix an error with installing drivers... seems a little excessive to me.
Ok, so how about BIOS? What kind of PSU do you have?
Well PSU is fine and u would get unsuitability not low FPS if that was the problem
The only differences between our setups or settings are:
E8400 @ 4GHz vs. E2160 @ 2.4GHz
X38 vs. G33
4GB @ 1000MHz vs. 2GB @ 888MHz
Catalyst 8.6 vs. Catalyst 8.7 Beta
Not that your performance isn't borked but thats a pretty big difference.
PCI-E stuck at 1x?
The LC stress test on my E6400+8800GTS512 is over 200
If you want me to i can set up a box out of spear parts and make a pentium D w/ 1gig ram and a 8800gts (G92) and see how it does @ 1600x1200.
EDIT-
AKeZtArGeT
I totally agree with you bro, i do this for a living as well.
OKAY! IT IS NOT A CPU BOTTLE NECK!!! Camaro I like your desktop background! That's my second dream car, I'll own the Scaglietti first thoughThough I'm telling you there is nothing wrong with your equipment, though you may be the only unlucky one with a 4850. I have the same monitor you have and I have the same operating system you have. Not to mention the same video card.
So all this inlies me to say it IS!! your motherboard, with something in the bios -OR- it's a driver recognition. I don't care what GPUz says, I don't trust that stuff. Go into your bios and make sure it's running at 16x, and if it is. It might seem interesting enough to see what your gpu would do if you ran it at 8x bus. You say you're out of town, but you should PM when you get back. I'm in Alaska, but I do this for a living and would be willing you give you some help.
Also just to prove to you guys it's not a bottle neck, I'm going to go home and OC my P3 to 800 mhz and run CS with an old VOODOO3! 16MB card and get 20+ fps. If you can't imagin a C2D doing a trillion times better.
Haha guys I totally appreciate your enthusiasm in the matter, and I'm not trying to say either of you are wrong. I have a strong hardware background but almost no software knowledge in terms of how things are programed to run on components. But the reason I keep bringing everything up is that I'm the type of person that exhausts every possible explanation when attempting to solve these types of issues, I'm just trying to be sure that nothing is being skipped over.
I was thinking motherboard as well, I wish my brother wasn't a selfish prick and would let me test my card on his 680i board. I'll be home Sunday evening and I plan on re-formatting first thing when I get there.
AKeZtArGeT: I will certainly PM you when I get back and let you know my status, I'm on EST btw. Also I love the F430 Scuderia and I have driven the 612 Scaglietti before, it was very fun.![]()
Now from what I hear, if i'm getting these almost EXACT same fps at even much lower resolutions then its a cpu bottleneck.
