478 / 775
M a d c o w
I was just wondering a 478 Motherboad have the same fitting to a 775 Motherboard as to measurement wise .
Thanks in advance for the replies
Do you mean the same fittings and measurements in relation to mounting them in a case? If you are then all ATX form factor motherboards no matter the socket have the same dimensions and the same holes to mount them. Like wise all Micro ATX boards are the same dimension as other Micro ATX boards. The same holds true fr all Mini ITX boards with other Mini ITX boards, BTX boards, etc.
The only difference you would have is if the 775 board is BTX, and I haven't seen too many of those. Otherwise it should fit fine because they are both ATX form factor.
