~$450 Gaming Build
Soller
Gaming(BFBC2, TF2, LFD2 and MMORPGs), Website development, Web browsing, School (Office)
~450 before shipping and handling
3) Where do you live?
Missouri
CPU, Ram, Mobo, Video Card
Antec Sonata III, 2x HDD, DVD/CD RW Drive
6) Will you be overclocking?
Not afraid to.
24" Sceptre @ 1920x1200
Soon
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
Not too sure. Preferable USB 3.0 and at least 3 SATA ports
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Yes. Win7 64bit
My current system is:
XIGMATEK HDT-S1283 120mm Rifle CPU Cooler I5 775 AMD compatible
OCZ Platinum Revision 2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model OCZ2P800R22GK x2
GIGABYTE GA-P35-S3G LGA 775 Intel P35 ATX Intel Motherboard
EVGA 512-P3-N862-AR GeForce 9600GT Superclocked 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card
Intel Core 2 Duo E7200 Wolfdale 2.53GHz LGA 775 65W Dual-Core Processor BX80571E7200 Overclocked to 3.2GHz
Antec Sonata III 500 Black 0.8mm cold rolled steel ATX Mid Tower Computer Case 500W Power Supply
SAMSUNG Spinpoint F4 HD204UI 2TB 5400 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
At this point, I'm not sure what options I have for my budget. Saw Antec NEO ECO 520C 520W posted in another thread going for 39.99 so I might pick that up to replace Antec Earthwatts EA500 500W, since that PSU is almost 3 years old. Other than that, I'm open for suggestions.
I'm not particular about where the parts come from, and there is a Microcenter close-ish to me.
Will that Antec Neo Eco 520C be part of that $450 budget?
Naw. My girlfriend ended up getting it for me as a late valentines day present
Nice! That sounds like a keeper! :)
In all seriousness though, here's what I recommend:
$240 - AMD Phenom II 965 Black Edition CPU + Asus M4A87TD/USB3 AMD 870 AM3 Motherboard
$41 - G.Skill Ripjaw Series F3-10666CL9S-4GBRL 4GB DDR3 1333 RAM
$183 - XFX HD-685X-ZNFC Radeon HD 6850 1GB PCI-E Video Card
Total: $464 plus tax and shipping
Yes $14 over budget but it's worth every single penny: Your resolution and games choices demands that much CPU, RAM, and GPU power.
This for sure..
So I went ahead and ordered the parts. I made a few changes to your suggestions though.
Grabbed a Sapphire Radeon 5870 2GB @ $200 Shell Shocker deal and grabbed 8 GBs of the G.Skill Ripjaw ram for 70.
Came out to being around $504. Little bit more than what I was wanting to spend but hopefully it'll last me another couple years.
I appreciate your help and input. Thank you.
wow thats quite a shell-shocker!!
If your talking about the One that is a179 After rebate right now then thats a really good deal considering thats a Eyefinity 6 Card..
