omaticrail
- Nov 9, 2005
My current machine (custom built) has been a trooper for many years, but it has too little RAM, and the only feasible way to fix that is to replace all the guts.
1) What will you be doing with this PC?
Gaming (primarily FPS and WoW), photo and video editing, browsing (often at same time).
Aiming for $400, all included. I can afford more, but I'm aiming for bang:buck.
3) Where do you live?
Near Seattle, WA.
4) What exact parts do you need for that budget?
CPU, mobo, RAM, SSD, HSF.
5) If reusing any parts, what parts will you be reusing?
CMStacker case (a monster), OCZ Powerstream 600, Benq optical drives (IDE), WD6400AAKS & WD2500KS, 8800 GTS 512, 4 port fan controller & thermal monitor. I have a solid water cooling system (would require new WB), but I'm a bit tired of the maintenance. Will switch to air if it can be done quiet enough.
6) Will you be overclocking?
Undoubtedly. Always have.
I have a Sun 24" LCD 1920x1200 (60Hz).
November, 2010.
9) What features do you need in a motherboard?
USB2 (rear and jumpers for front) (USB3 a bonus). SATA 6Gb/s. Firewire (or a free PCI slot). RAID. IDE is a must for my existing optical drives, but they could be replaced if it made monitary sense. Would also like high-end sound with SPDIF 5.1 (optical OK, but coax preferred). Could go with a separate card if space and $ make sense.
I already own Windows 7 Ultimate 64 (retail boxed).
AMD or Intel, doesn't matter to me. I've had all AMD the last 10 years or so. I believe in having lots of memory, and fast storage, so RAM and an SSD are top priority. From other posts I've started to get an idea of what I want, but this list is mismatched and over the target budget....
163 Combo Biostar A880G+ AM3 (a dinky little thing that'll get lost inside my Stacker) & Phenom II X4 925 Deneb 2.8GHz AM3
125 G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL9D-8GBRL
$134 OCZ Vertex 2 OCZSSD2-2VTXE60G 2.5" 60GB SATA II
A thus-far-unidentified monster air cooler.....or a cheap waterblock.
I've had good experiences with MWave, and Newegg, but will consider other sources with a solid reputation.
Near Seattle, WA.
November, 2010.
