$400 to spend - Intel CPu/MB help!
ssratt
Hi, as it says I now have $400 to spend on a new MB and CPU, I am not TOO concerned about O/C but I would like a decent gaming setup.
My only requirements are
DDR2 (4)
Crossfire compatibility
6 SATA (can juggle that if needed)
This is to replace what is in my signature
I MIGHT be able to go $450 if I stretch it
Thanks, that is starting to make me hate having to wait a week and a half, (withdrawal symptoms kicking in)
If other suggestions would like those as well
(Intel instead of Amd? = one fanboy seeing the cpu light after many years-at least for now)
Those choices are pretty good price/performance parts for what you're looking for. If you can live without crossfire you can get away with a cheaper board and more CPU. Might even be able to get a Q6600 instead of a E8400 and still fall inside your budget.
OK, well it looks like we have a M/b winner, :D
CPU wise it looks like i just became a newbie again...
the 6600 lists at a 2.4(2x4m l2) while
the 8400 lists at a 3.0(1x6m l2) now like I said here newbie level time, does the 6600 O/C THAT easy that it can play at 3.0 or above? (assuming the Newegg list+ 2 1g corsairs and 2 1g Gskils) other stuff SBLive, ATI3870
OS will TRY to be Vista 64 (had problems on this setup), though might slip to 32
If so... are there any quick setups that will help me push it up there (clock.mem, etc,etc..)
Thanks so much in advance
i would imagine 3ghz wouldn't be hard, i've seen good steppings get to 3.6ghz sometimes.
trying to keep it alive.. for O/C info
it does look like in the benchmarks the quad blows away in decoding/encoding -work stuff
and is darn close in games, down only because of the 2.4 instead of straight 3.0 (which a general O/C should fix..settings help please :confused: newbie on these -suck at the math to really do it on my own)
Last CPU I really O/C was a Celeron 300a (yeah THAT ONE, and i used the general "O/c settings" that were out there)
the gigabye ds3l and the dfi dk p35 are solid OCers. Dfi you could squeeze more out of, but its not for novices, but there are guides online you can read
im on the same boat
im thinking of going with the E8400 and DK P35 ...
you want pure gaming,hardcore shit .. so yes, the E8400 will do great.. later on when the newer 45nm get cheaper and games will REALLY use 4 cores, you could upgrade to a newer cpu
Don't forget that the Q6600 2.4GHz is a quad-core, while the E8400 3.0GHz is a dual-core. I hope that's not being condescending, but I wanted to point out that there is more of a difference than just the clock frequencies.
