Site: http://www.ebuyer.com/ (but can source parts not found here from other sites)
I want to get a really nice case for this build. I have been looking at some from Lian Li, and so far I've come up with this: http://www.overclockers.co.uk/showproduct.php?prodid=CA-174-LL&groupid=701&catid=7&subcat=187 Suggestions?
Modular PSU preferred.
1) What will you be doing with this PC? Gaming? Photoshop? Web browsing? etc Light gaming, mainly web browsing
2) What's your budget? around £400
3) Where do you live? U.K
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific. The case and everything inside
5) If reusing any parts, what parts will you be reusing? Please be especially specific about the power supply. List make and model. None
6) Will you be overclocking? Yes
7) What size monitor do you have and/or plan to have? Have 1024 x 768
8) When do you plan on building/buying the PC? ASAP
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc. Nothing special
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit? Yes, x64
