$400-500 build for multi-tasking interior design software
warmchords
Hi all, trying to put together a new build on the cheap for my girlfriend. She's studying interior design and needs something that can multi-task programs like AutoCAD Architecture, RevIt Architecture, Google Sketchup and Photoshop. Trying to keep it under $500 if possible.
Multi-tasking AutoCAD, RevIt, Photoshop CS5, Google Sketchup. Also running Ableton and some video editing software.
$500 (not necessarily including tax and shipping)
3) Where do you live?
Nashville, TN
CPU, RAM, HDD (1), Mobo, Case, GPU, DVD burner, PSU
Not re-using anything.
6) Will you be overclocking?
Probably not.
19" ...cheap, old LCD. Might be the next upgrade but not right now.
ASAP
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
USB 3.0 would be nice but not a requirement.
Yes, Win7 x64
Hopefully this isn't too much to ask within my budget, I'm assuming 6gb of RAM might be required to be safe, and can't skimp too much on the processor. Thanks in advance!
Your budget is probably a bit too low. If you raise it to a little over $600 you'd be in a better position. For that much you could put this together:
http://techreport.com/articles.x/20722/2
You could knock the price down a bit by getting rid of the 6850 and replacing it with a half-height budget card. That's assuming you're not going to be doing any gaming on this build (and since you didn't list that, thats probably the case?)
$500 is enough:
$112 - AMD Phenom II X4 955 Black Edition CPU
$75 - MSI 870-G45 AM3 AMD 870 ATX Motherboard
$72 - 2 x Patriot PSD34G13332 4GB DDR3 1333 RAM
$60 - Sapphire Radeon HD 5570 1GB PCI-E Video Card
$61 - Samsung Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s Hard Drive
$24 - Lite-On iHAS-324-98 24X SATA DVD Burner
$45 - Antec Earthwatts Green EA380D 380W PSU
$40 - Coolermaster Elite 310 case
Total: $489 shipped
Thanks guys, this gives me some options. The lady is selling frozen lemonade at Bonnaroo this weekend and keeping the tip jar, so I guess I'll know what my budget is when the festival is over, haha.
