$400 2d CAD System Build Help!
1) What will you be doing with this PC?
2d Autocad 2009 (2012 by end of the year), office setting, occasional Sketchup drawings. NO Rendering will be done on this system.
$400 USA before shipping
USA 3-hours south of Kansas City
4) What exact parts do you need for that budget?
Motherboard, CPU, GPU(if needed), Memory, HD, PowerSupply*(see next answer)
5) If reusing any parts, what parts will you be reusing?
I have cases, monitors, dvd drives, mice, keyboards. Depending on the setup I could possibly have a power supply but they would be from a server or old p4 dell systems.
6) Will you be overclocking?
No, not at the office!! lol
Possibly 2 but for now 1 Acer 22" it's newer I haven't used it yet so I don't know the max resolution.
Now
9) What features do you need in a motherboard?
reliability
10) Do you already have a legit and reusable/transferable OS key/license?
Retail Win7 64bit and 32bit
I am posing this question to you guys because gamers really know their crap. I don't need a super computer just a simple 2d cad machine that will blow the socks of the old Dell P4 system I'm using. It's struggling with Autocad 2009 and needs help.
I don't need large storage because all working files are stored on the company server. The video card just needs to be decent, nothing crazy hot running OC'd card, it's possible to get away with onboard, but I'd like to be able to run 2 monitors and that might be a stretch with onboard.
This is what I came up with, but it's a little over the budget, I put $400 because with shipping/mail-in rebates it could get close to $425-50 and that's putting the boss in cardiac arrest.
http://pcpartpicker.com/p/evFs
I was thinking there is a cheaper video card that would work but there is so many options it's confusing. Is this the CPU & board gonna be ok for a while or not?
Buy this Crucial M4 128GB SSD deal RIGHT NOW:
http://www.buy.com/prod/crucial-m4-128gb-2-5-sata-iii-solid-state-drive-ssd/221150373.html
It's of far far greater quality as well performance than that OCZ SSD. So the second you read this, buy it now before it runs out. Even if you miss the deal. don't get that OCZ: It's really not a good SSD.
As for cheaper video cards, you save a little money with this GPU:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161403
As for PSU, that PSU you chose is crap. Go for this higher quality PSU instead while it's still on sale:
$38 - Antec Earthwatts Green EA380D 380W PSU
ok, will do. what about the MB & CPU? Is this ok stuff, for what I'm doing?
