4 port kvm switch - pro/cons
f_kruegar
ok since we started a computer repair shop.. looking to get a kvm switch.. i used to have one long ago but now there are so many new ones with hotkeys to switch.. what is a good one that doesnt cost an arm and leg.. any good deals? anyone have one they aint using?
This is the switch that I am using and it is great !!!
Linkskey
They get pretty expensive especially the cables, are you sure you only need a 4 port you might want to go bigger and plan for expansion. It will cost more now but save you in the long run.
OregonLAN said:
That would be Linkskey, not "Linksys" and yea I would recommend them too...
haha wow yeah that is what I mean, I was just talking about my router that was stuck in my head.
thanks guys.. i will check that out.. i did find this site monoprice.com that has a bunch of them for not too expensive.. what you guys think of those?
i have a belkin 4 port soho, ps2,usb,audio, and it rocks. does everything i want.
But for the price (the "belkin" name) , you could probably find a unit to handle more for the same price.
Belkins suck. I had one and it totally screwed up with the mouse, scrollwheels and such. Only good thing about them is that you can find some fool willing to pay too much for them on Ebay.
Get a Cybex.
