Hello,
My front case's 3 fans are RGB and have 4 Pin RGB cord that
is supposed to connect to included RGB controller in case my
motherboard does not support RGB.
However my motherboard does support RGB, I have Gigabyte
Aorus B450. This means I can connect 4 Pin RGB cord to my
motherboard but don't know where.
My motherboard has 4 Pin LED_CPU connector that is described
as 12V G R B and it also has 5 Pin 12V G R B W connector.
Where should I plug 4 Pin RGB cord to power 3 front fans?
My case model is MasterBox MB511 RGB
Thanks.
Thanks.
