4 monitors off one machine! Solution?
speakerlab
Hello,
I am in need of a solid and proven solution to run 4 20" lcd monitors off a machine running Vista ultimate. The LCD are Dells with both vga and or DVI. Currently I am running dual monitors and find myself looking for more space often.
Thank you,
Tyler
Dual video cards is what I'd run. Depends on what internal connections you have.
Four displays might be a little weird if they're set up horizontally. One on either side of the primary, and one above it would be nice.
Thanks for the quick response. I should have been clear and asking what other are running; as in the past I have had issues running two dual output cards from the same manufacturer.
Tyler
