4 GB max boards
Ironsoap
I'm looking into getting this mobo...and all looks well, specifically price, but I notice that it only supports up to 4 GB ram...does that mean that if I put 4 GB (I plan to) in it, it's gonna be too stressful on it? will I have errors in windows saying that I only have 3.5 GB of ram or something? sorry to sound like such a loser.
From what I've seen, you're not going to be able to use all 4GB unless you're running a 64-bit O/S like XP64 or Vista 64-bit. You'll get stuck with the 3.5Gb (or so) limit because of the 32-bit limitation of the O/S.
I'm going with 64-bit vista with this current build. I just don't want to buy a board that can claims to be able to handle 4 GBs of ram when that's the very max it can take.
Change the link up in the OP...it just gives a list of mobos, it doesn't point out which one specifically you were looking at.
I think you'd be alright. With the AMD CPU's it comes down to the CPU memory controller. If you can, I'd look and see if you can find a board that takes 2x2GB sticks as the memory controller on the AMD CPU's seems to have less issues with only 2 sticks as opposed to 4 sticks.
Since the board only takes 4GB of memory and only has 4 slots, it looks like 2GB dimms are incompatible with the board.
Are you already set on and AMD cpu.. if not then the P5N-E will go upto 8GB with 4x 2GB sticks
That MSI board is the 570 chipset while the eVGA is the 590. If you're going to get a 570, you might as well stick with the Asus. Personally, I've had better luck with Asus than MSI.
