1.10, using Windows 7 x64. Did 128k stripe when I created the RAID 0 array.what firmware version are you using with those drives, and what OS? you should definitely be getting better numbers than that...each drive is capable of 250 mb/s, and although hey arent going to scale linear, it should be near linear, so you should be nearly saturating your onboard raid controller (ich10r) at around 600 mb/s
well then you should definitely be getting some better numbers than those! what stripe size are you using? also have you dont the normal ssd tricks, disable defrag, indexing, etc? also enabled advanced performance on your drive from within the OS?
well if you are using the onboard raid controller you definitely need to get the chipset drivers on there, especially the raid ones. it has a specific raid drivers for that ich10r, try that first. I have the same board![]()
Is the write back cashe enabled in device manager? It has to be to be close to maxing the controller out as well as having it enabled in Intel Matrix Storage Manager.
I Fixed my problem . I had to turn off Windows write-cache buffer in Windows 7. Now I am getting 500 read speeds!
I just went from 300MB to 600MB a second. Yes I can tell a difference.Seriously, do you notice any "real-world" difference?
I just went from 300MB to 600MB a second. Yes I can tell a difference.![]()
Question: when you have your 3 drives hooked up together, you're getting the combined maximum speeds of 3xSATA300 ports, right? I always worried that if your drives were too fast (SSDs only), you'd hit the SATA bus limit of 300 MB/s, but it seems like that's only for each individual drive.
Sounds good. I just bought an X25-M, but I'm thinking it may be a good idea to spring for another when prices are cheaper.Ideally that's how it would work. In reality most motherboard raid setups can only handle 400ish MB/s max read speeds. The Intel ICH10r is good for 600MB/s. The better PCI-e X8 hardware raid controllers are good for upwards of 900MB/s
