fightingfi
- Oct 9, 2008
Pure ownage of that GTX 295 which benefits from physX.
anyone who went from a 4870x2 or gtx295 to the 5870's already knew how close those three video cards are in performance, which makes this 'revelation' that three 5870's produce impressive results totally pointless. there a few instances where two gtx295's out pace two 5870's so a comparison between two gtx295's and three 5870's would have been interesting and informative. this article is little more than a video card jerk-off session.
actually, I moved from GTX 295/4890CF to 5870, and the performance is not even that close..
even when FPS is that high, but its not as smooth as the same fps in 5870...
the article isn't about how smooth the performance was, it was just raw data. using the same drivers for 58xx and 48xx cards, i found the 4890 cf setup genuinely faster than the single 5870 in 3 out of 4 tests.
not really, hardware-accelerated physx was off in batman in the review. so only cpu physx was being used - therefore the 295 didn't benefit at all.
did you not try the link? i did test warhead and you're absolutely right about it being smoother, but again that's not what the pc perspective article was about. all they did was run three 5870's against a single gtx295 and say, 'wow did you see the performance difference?' well, no shit three 5870's are faster than a gtx295, but what do the numbers look like when you challenge three 5870's against two gtx295's. now that would make a more interesting article.
I didn't see that. Are you sure?
What about Vantage?
i was just looking at the picture of the in-game settings they used, that's all - it's the last setting shown on the picture right above the first graph benchmarking the 1680x1050 res.
http://pcper.com/article.php?aid=796&type=expert&pid=2
can't comment on vantage though. haven't paid attention to 3dmark #s in a long time, lol.
yea, I did look at the link but they didn't mention anything about it.. just pure raw data..
that is why I absolutely hate those article for none sense.
the numbers look good, but actual thing is, the game experience does not.
btw, this is not just about the smoothness I am talking about.
this is about the actual fps. make your character stay there, don't or do anything, and just look at the screen.. it shows 30+fps in 4890CF/GTX 295. but it looks less than 10fps.
not quite sure what cause that, but thats the most noticeable part I remember.
I did remember it happen on some other games too, but not exactly sure which one...its been awhile..
Decent scaling for 3 gpu's. But $1200 for video cards?![]()
I saw that but that may be the view of the settings for the hd5870 which can't use PhysX anyways. The article doesn't really say if physx was used on the GTX295.
The Vantage score is high for GTX295 and based on the score it does appear to have physX enabled. Not the best review with details like that missing.
exactly - so for a fair "apples to apples" comparison, they have it disabled for both the 5870/ 295 cards. i'm sure if they had separate settings they would have stated as such. moreover, a single 295 would never get those kind of average frame rates with hardware physx enabled. they would be much lower due to the heavier physics processing load. if you go to driverheaven, they had a recent batman analysis of hardware physx performance that will corroborate what i have said based on their numbers. as far as the vantage score, physx should only be enabled in software. otherwise the score would be substantially higher with it processed on the 295. again, they do this otherwise it wouldn't be a fair comparison. it doesn't matter though since 3dmark is pretty useless, imo.
i mean the link in my post to my own test of the 5870 vs 4890's in crossfire. and about the frames showing 30 but looking like 10, that's micro stuttering. i previous posts you've said that micro stuttering was eliminated in the 48xx and gtx2xx series of video cards. now you've experienced it for yourself.
Well I have no problems appreciating 3dMark benchmarks.
Also I hear ya on the rest of your comments but that review is still lacking because the review didn't really go into details regarding the PhysX being enabled or not. It's a blank spot in that review.
Apples to Apples it's going to be cool to see ATI Stream computing power being enabled later on down the road to help out 3d performance like PhysX does for NVIDiA cards.
When that happens it will be a fair apples to apples review.
no dude. what you saw is micro stuttering. just because it happens on occasion doesn't mean anything. you just experienced constant micro stuttering with the 3870x2 and 9800gx2.
i found toms review of the 5770, your new favorite card, and it shows what hardware physx should look like on and off:
Right now my favorite single video card is the HD5850. Has tons of over clocking ability and raw power.
I'd love to have 2 of them for Xfire destruction.
Too much money for my budget right now though. Below the Xfire HD5850 configuaration my next weapon of choice is HD5770 in Xfire. 2 HD5770s in Xfire should perform right in between single HD5850 and single HD5870 performance.
Price wise the perfomance seems to scale with gpu power.
micro stuttering is a calculable phenomenon, whether you see it is an entirely different matter. some people are more perceptive or sensitive to it than others. but what you saw is the very definition of micro stutter. get over it.
believe what you want to believe. i don't care. indulge in your delusion.
this is why you don't shake the baby.
Why? To see if 3 gpu can beat 4 gpu? I suppose you need to do something to help the weaker nvidia side.
2x 5870 owned the gtx 295 in all those benches. That's straight up 2 gpu vs 2 gpu. 3x5870 just makes the ATI victory margin even more humiliating.
