Hi,
In the 3ware manual it states:
Enabling and Setting Up Staggered Spin-up
You can set the number of SAS and SATA drives that will spin up at the same
time and the delay time between drive group spinups. This does not apply to
SAS or SATA drives that are attached to an expander.
With my Norco RPC-4224 when I enable staggered spinup with Hitachi 7K3000 drives it only shows 2 drives and boots as degraded; does anyone know if Staggered Spinup works properly with a Supermicro Chassis or do the drives literally need to be connected to the raid card via fanout connectors for it to work properly?
