3D Refresh Rate Override (LCD improvement)
nicoliani
LCD screens run at 60 Hz. For desktop application there is nothing you can do to improve it. Driving the Hz up will result in bad tearing. For games although there is an option to increase the refresh rate called "3D Refresh Rate Override" and have it look beautiful ingame.
If you have an ATI or Nvidia card there is an option in the control settings software CCC and ForceWare where you can choose a higher refresh rate than 60 Hz. So when you start your game your LCD auto goes into 75 Hz.
When I first used it I was impressed. I never was a fancy of the qulity for games with LCD screens but now it is magnificent. Games look so beautifully, lively and you feel like you're inside the game.
It's the same difference what you noticed when you went over from analog to digital TV, or when you first saw a movie or trailer in HD format.
I haven't tried any rate over 75 Hz as I don't know if LCD's supports that. But setting it to 75 Hz wouldn't give any LCD any issues and is safe for your LCD but I now when someone does runs over 100 Hz it can happen that games don't start.
Please let us now if you experienced what I have experienced.
I run it with dvi on graphic and vga to LCD as I don't have any dvi port on the LCD. I can see from my screen menu that the value goes to 75Hz. When I go vga/vga it goes to 75Hz. But still I experience better image quality dvi to vga. It said that dvi is locked to 60Hz and can't go over that but I just show that I get 70Hz.
I though 75hz on lcds didn't really work even if your lcd has the option because it drops the frames or something to keep up.
No offense..but that was very hard to read. :p As others have stated...the traditional "refresh rate" doesn't really work the same way with lcd's as it does a crt. Any experimenting I've done with going above 60hz has only caused problems...but if it works for you (placebo effect?) then it's all good.;)
LCDs dont need to refresh like analogue monitors.
An analogue monitors picture will fade unless the electron beam refreshes the picture. The number of times this occurs per second is the frame rate the display is running at.
If you match the refresh rate (the frames per second output from the video card) to this or a multiple of this you will get no on screen tearing.
An LCD will keep the same picture unless there is a change and does not require any refreshing of the picture to keep the same picture on screen.
Each pixel will hold its value like a memory location does.
If the whole picture changes then essentially the effect from both types of display will be the same and tearing can result if the rate at which frames are being sent doesnt match the rate at which the display can refresh.
LCDs currently are offered with 50, 60, 70, 72 and 75Hz refresh rates.
For best results you need to match this as closely to the fps you get in a game when not using VSync.
Of course the fps varies throughout a game and is different between games too so this makes it practically impossible to use as a guide.
I rarely use VSync and see very little tearing but thats down to luck more than anything.
There are 100Hz LCD displays available but these will not display 100 fps, they do 50 fps and interpolate between frames to make the action clearer/smoother.
So whether changing the refesh rate improves tearing or not is down to the fps you are getting at any particular moment in a particular game, and compares to the refresh rate you have set for the display.
Quite simply, you can get more tearing or less tearing by changing to ANY value refresh rate. You cannot make a blanket statement that 75Hz is better than 60Hz because it can easily be not true.
The cure for all this is to use VSync, thats what its designed for :)
Placebo effect? No, I was not expecting anything when I highered my rate, I didn't even know what refresh rate was. I got 75Hz as it showed up on my LCD, and I experienced a great image improvement, and no I don't use vsync and don't need to.
Besides "3D Refresh Rate Override" doesn't work the same as refresh rate so you cant compare those two things.
Actually a 3D refresh rate works exactly the same as a normal refresh rate but, depending on game settings, may be greater or less than the 2D one but other then that it works and for all intents and purposes is the exact same thing.
You did have a reason to use VSync and may still have.
Run winamp with Milkdrop doing visuals. If the Max Framerate is set to something other than your refresh rate (or double it), you will get tearing on some of the visuals (you might need to wait a while).
If this tearing doesnt bother you or doesnt occur often then fair enough :) and well done for finding another solution that works on your PC.
You wont get rid of all tearing unless you use VSync though.
Hehe.
The 3D Refresh Rate Override setting comes from OpenGL and DirectX not properly setting the refresh rate in games. It started with the first drivers for Windows 2000 and it was an aweful bug until nVidia fixed it with adding this setting.
It could go either way depending on the frame rates you get without Vsync on.
What you're saying does make sense cos lowering the hold time from 16.6ms to 13.3ms can help to reduce motion blur, but its only effective on games that are rendered at 75fps or higher.
PS: People with high resolution monitors are stuck with 60Hz unless they switch to VGA.
http://www.behardware.com/art/imprimer/641/
On the left, a 50 Hz sequence and on the right, the result at 100 Hz​
Well thats not what your LCD is doing. So I do not see how that article is relevant to the subject at hand.
That article is some year old. Do we have LCD monitors that do 100Hz (17''-24'') today? As they where referring that Samsung would start making 100Hz monitors.
The single link DVI doesn’t have enough bandwidth to enable 100/120Hz at high resolutions. And the frame interpolation doesn’t always work. It might actually cause more problem instead.
Just wait for a while for CMO’s “Overdrive v2”
Hehe.
That has more to do with 2000 and Xp then the drivers.
Windows 98 always changed the refreshrate to the highest possible when starting a game. In 2000/ Xp is always lowered the refresrate to that fckng flickering 60Hz. Happily they had that tab in the driver to force the refresrate to stay high. In later version they removed that particulary tab from the driver, but with adding one register it became available again. How it is with today's super-pimped, glitter glamour layout non-functional drivers, I don't know. I had give up, because I have my CRT only for 2nd monitor so I don't care anymore, because my TFT needs 60 Hz.
It says:
Normal LCDs: 60 or 75 Hz ?
Our conclusion from tests, most of all our impression from games, is unanimous : 100 Hz rendering is much better than 50 Hz. Response time doesn´t change, but afterglow is much different. Increasing frequency considerably improves the fluidity of sequences and resolves the problem of persistent images due to the insufficient reaction time of crystals.
We logically came to ask ourselves about the optimum frequency of normal LCDs. Most support 60 or 75 Hz. We did a blind test of 6 monitors at the two frequencies. In the first case, there is theoretically one image every 16.7 ms and for the other this figure is 13.3 ms. Compared to our example of increasing from 50 to 100 Hz, we should logically get closer to the reaction time of 100 Hz at 75 Hz with our LCD monitors….but this isn´t what we found.
We found the following:
2 didn´t support 75 Hz and we would have a black or unstable image.
2 said that they supported 75 Hz, but when we measured the time between images we realised that they were in fact at 60 Hz.
Finally, the last two really ran at 75 Hz…partially. In fact the monitors really displayed four images and then skipped the fifth. The sixth one was displayed normally. When we looked at the results, we realised that this skipped 5th image was to resynchronise the monitor at 60Hz. In fact, it really displayed 4 images in 67 ms whether it was at 60 or 75 Hz.
