If I had to wager, I'd say this is beyond the realm of physical possibility.290X2
They had to downclock them heavily to do that, over 150MHz per GPU, and the 580 Fermi GPU draws less power than the 290X Hawaii GPU does. So even if they do find a way to build this, it will almost assuredly be notably slower than the 290X boards.They managed to fit two fermi 580 GPUs on a single board. I think they could get two 290x GPUs (albeit a bit underclocked) on a single board.
me using a prodigy and i can only have 1 GPU, id be all over a 290x2. As long as the heatsink wasnt a complete failure. Its the only regret i have with my 290 is the cooler
