Just2stoned
- Mar 20, 2006
I have 2 Diamond viper HD3870's. My first attempt at running 3dmark06 in xfire was a catastrophic failure, but not in the sense that you guys are thinking. My first score was a 4319... yes thats total 3dmark06 score. Both cards were installed right. I tried many many things to get improved performance but sadly nothing helped. I took 1 card out as a last resort and BINGO! 3dmark06 ran like a champ and got me a 10880 score with just 1 card and mild overclocking of cpu/mem/vid. Fantastic, 1 card works. I turned off the machine and put the other card in by itself to make sure both cards worked. It worked just as good as the other one.
I then proceeded to put the 2nd card back in, this time with no bridges so I could let windows detect the 2nd card by itself. After it found the 3800 series card(3870) i looked at CCC and it said my bridges were disconnected. Ok, I knew that so I shut down and connected the bridges. Booted back up and went into 3dmark.
Same shit. First 3dm06 test with 1 card starts out at 70+fps, with the 2nd card installed it starts out at 20fps and never gets any higher.
I think it's worth mentioning that if the 2nd card is plugged into the mobo, even if xfire is disabled in CCC, 3dmark06 will NOT get any higher than 20fps in test 1. It will get up to 40fps on canyon flight, but I usually can't bare sitting through the full test when it's doing this. I have to completely remove the card from the case to get 3dmark06 to work right.
I read many many many similar "low performance" xfire threads but these guys at least got better than 10k scores with xfire enabled. My 3dmark absolutely chugs in xfire. it's about a 75% loss in performance with the 2nd card plugged in, which makes me ultimately think it's my not so cheap($140 isn't cheap) but crappy motherboard. The only thing I haven't tried yet is taking a stick of ram out, but that will be today when i get home in 1 1/2 hrs.
Can anyone confirm that having 4gb (2x 2gb sticks in dual channel) in xp pro 32bit is a bad thing for xfire? This was a suggestion by 2 users on other forums, take 1 stick out. Another one to try was change HTlink speed from auto to 1ghz. Thats it though. I've run out of things to do other than these last 2 ditch attempts to get xfire to work.
Did I mention that with 1 card every game I have plays beautifully? Crysis @ high, COD4 @ extreme, LP(lost planet) @ extreme settings.. If I put the 2nd card in and enable xfire, games will still look good but I get exactly the same fps so it's like the 2nd card isn't even there.
