oh okay I see how that works, and it's pretty interesting I'd very much like to see what kind of overall performance. I guess I should of wrote my original post more clearly to ask the question i'm looking to get some sort of possible answer even though the tech isn't available. Does anyone think one 3870 would work in crossfire with one 3870x2? I guess saying tri-crossfire was the wrong term, but technically it would be 3 cards running together. Any thoughts?
PSU requirements? Too early to tell, but supposedly it'll be the same as having 2900XT's in CF so i'd say you'll want a 600+watt PSU to be safe.
CF x 3870 probably in the neighbourhood of 750w, since these cards use less power than the previous R600's.
Maybe for two 3870x2 cards but not for two 3870's.
Agreed, 750W for just two 3870s sounds high.
According to H's tests, the total system load (under full load) was 268W with one card. I know one needs overhead and all, but I have trouble seeing 750 watts being needed.
Wish we got a statement from AMD on this tho..
edit: fixed typos
How much that matters, I don't know
What, like a list of certified PSUs?
http://ati.amd.com/technology/crossfire/buildyourown2.html
Looks like the PSU I'm using (Enermax Liberty 620W) for two X1900s will work fine. Interesting as it isn't certified for 2900s, showing a definite improvement in power consumption.
No the 3870x2 is supposed to work on any motherboardDo you need an ATI/Intel chipset to run one 3870x2? I assumed it would function like the 7950X2 where it would work with any pci-express board. I'd consider getting a 3870X2 to play with but all my computers are running nvidia chipsets.
