3770k voltages Help
usoldier
Hello, ive been having some wierd data corruption on my ssd iam wondering if my offset voltage is set too low for idle state.
Currently iam at 4.2 overclock with 1.2v load and at idle x16 at 0.850v is this too low for the idel state?
I don't have ASUS mother board so I am not familiar with your BIOS but i think your problem may be related to unstable Memory.
Have you tested your RAM settings for stability?
Try Prime95 or IBT
No.
Need to test ram before you boot into BIOS that way if the ram is unstable it will not screw up the hard drive OS.
Memtest86+ works well. Get to a stable operating computer and make bootable USB drive and boot right into memtest86+.
I would second memory issues. I dont think unstable CPU voltages have ever corrupted HDD storage..
What is your offset set to? If you're at 1.2V full load you should be about at stock right? If so, I doubt your core voltage is the problem
