37 Westinghouse / Headaches
Discussion in 'Displays' started by jhills, Feb 4, 2007.
  1. jhills
    jhills n00b
    3
    Feb 2, 2007
    I was wondering if anyone else gets headaches with larger LCDs ? Any setting suggestions would be appriciated. thanks
    [​IMG]
  2. taylorwilsdon
    taylorwilsdon 2[H]4U
    2,286
    Aug 21, 2006
    That Dell is about to fall off :p
    Anyways, try getting a deeper desk or wall mounting the Westinghouse so that you're farther away. Also, lower the brightness/backlight.
  3. WicKeDcHilD
    WicKeDcHilD Gawd
    568
    Oct 4, 2006
    wall mount the westinghouse and get a ergo arm for that dell Lol...
  4. Voltron
    Voltron Limp Gawd
    137
    Mar 9, 2006
    Yeah, your sitting to close. With a set this size u need to be about 4 feet back. Get ya a wall mount and pull your desk back some.
  5. [H]ump
    [H]ump [H]Lite
    119
    Jun 22, 2003
    your mom always told you that if you sat that close to the tv you would go blind..... whoda thunk?
  6. JacobC1983
    JacobC1983 2[H]4U
    2,608
    Sep 4, 2006
    you are sitting too far away.. move the westinghouse closer to you and lean in a little bit
    the problem is that you are too close to that dell monitor.. move it a little further back and you won't get any more headaches
    and if you still have headaches.. turn the westinghouse backlight up a little bit
    that should do the trick!
    need more help.. just let me know!
  7. Ryle
    Ryle [H]ard|Gawd
    1,053
    Jul 16, 2006
    lol that desk is not ment for a 37" monitor..
    wall mount that thing and pull back desk some or get a new desk.
  8. jloutz
    jloutz [H]Lite
    109
    Jan 7, 2005
    $1200 LCD monitor on a $12 desk. You ever heard of balance?
  9. Jared701
    Jared701 [H]ard|Gawd
    1,587
    May 9, 2002
    pretty sure thats a dorm room from the look of it and if thats the case he doesnt have a choice about wall mounting it or what desk he has
  10. Scyles
    Scyles [H]ard|Gawd
    1,192
    Jul 30, 2006
    Its highly likely that you're getting a headache from the S-PVA's color shifting. My girlfriend gets a headache from my 21" S-PVA. I'm sure she'd be puking from that 37". Notice the center of the monitor is darker than the rest of the monitor, now move your head around and you'll see the dark spot move with you. Its a poor viewing angle issue.
  11. hamm3rhead
    hamm3rhead Gawd
    537
    Jul 14, 2004
    pull the desk forward and shove a shelf, made out of returnable beer bottle boxes and a couple pine boards. it will look like it belongs in a dorm and your corneas will have some time to heal.
  12. Kaash
    Kaash Limp Gawd
    237
    Aug 17, 2006
    yea, i had the same problem with a different monitor, the Sony Bravia 40inch. thing has 7000:1 contrast and was blinding plus i was only 2 1/2 feet from it so my neck also hurt from having to look up. When i move to Japan and i'm still stuck in dorms, i'll be buying a small laptop desktop that can be wheeled around and put my wireless keyboard and mouse on that and set like 5feet away. i'm screwed till i get my own appartment =/
  13. Spare-Flair
    Spare-Flair [H]ardness Supreme
    7,471
    Apr 4, 2003
    When you sit too close to large monitors, especially ones that are more inclined for home theatre like the Westinghouse models, you get headaches and nausea.
    I just spent a lot of time up close on a 42" Westinghouse. Same symptoms. The response time of the screen is being picked up by your brain on a subtle level and the large size occupies most of your forward vision leading to those problems. Move back a bit and it should be easier. The high contrast levels also play havoc with your eyes and brain.
  14. g1xx3r
    g1xx3r [H]ardness Supreme
    5,496
    Nov 30, 2005
    Send me teh Westy and I guarantee the headaches go away immediately..:D Seriously though,like its been said already,youre too close..
  15. claudione314
    claudione314 Limp Gawd
    264
    Dec 4, 2006
    That indeed looks like a dorm room... looks pretty much like mine. College students cannot wall-mount, of course. We could return the standard desk and bring our own, but the less stuff to carry on move-in/move-out days, the better. He's using the desk's keyboard tray, so that should be far enough... about 4 feet, I'd say.
    EDIT: Here's my own desk; setup to be updated soon; computer in sig arriving today!
    [​IMG]
    Large version
  16. fireburster
    fireburster [H]ard|Gawd
    1,265
    Mar 29, 2002
    im assuming a fellow iowan buy the keyboard pad there. Nice monitor.
    I got a 37 inch for my basement the 1080i version from bestbuy and its nice.
    where did you get it local at?
  17. jhills
    jhills n00b
    3
    Feb 2, 2007
    I got it at Conns. I had some existing credit with them. $1081 with tax.
  18. jhills
    jhills n00b
    3
    Feb 2, 2007
    Can I use non-returnable bottles ?
