$350 Mobo, Cpu, Ram upgrade
Nightcast
[H]ere for the Blow!
Hi I've been looking to upgrade my pc for a few months and have been lost on the internet with all the new tech. I'm only looking to upgrade my Mobo, cpu and ram and would like it to last me another 6 years. Onto the list
Web browsing, watching 1080p movies and very little starcraft2
$350 Yes and Yes
Michigan, Micro center within 15 miles
CPU, Mobo, Ram.
CM690 case, 8800gtx, Antec HCG 520w PSU, and CM 212+
6) Will you be overclocking?
No
23 1920x1080 and 19 1440x900
Between now and the end of july.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Don't think I need anything special does need SATA 6Gb/s
Been using Win7 32bit but my brother has a extra copy of Win7 64 bit if I need it.
Grab the Core i5 3570K + Asus P8Z77-V LK Motherboard combo from MC for $270 plus tax.
Then grab this RAM:
$40 - G.Skill Value Series F3-10666CL9D-8GBNT 2 x 4GB DDR3 1333 RAM
And you'll be set. Yes get that copy of Windows 7 64bit.
Maybe I'm missing something but after looking at the MB it shows a Hdmi, display port, vga and DVI but it says no onboard video. So what are these ports for?
For most current Intel CPUs and platforms, the "onboard video" is now integrated directly into the CPU itself, not the motherboard. So once you pair that motherboard with the CPU I recommended, you'll get onboard video capability.
Thank you for that. I'm going to head over to MC tomorrow to look at some stuff. Is AMD making anything that can compare to the intel for cheaper?
