So my buddy at work wants to build his next computer. He currently has some Frankencomp that started off life as an eMachine 5 or 6 years ago. I don't think anything can be salvaged. It probably has an IDE DVD burner.
Web browsing, light photo and video editing, may get into gaming in the future, but can spring for $50 to $100 on a GPU when and if that time comes
$350 --- $300 of that must be spent at Amazon because of gift cards. I think he has Amazon Prime as well so most shipping should be free. It doesn't have to be Prime Eligible though if it's cheaper through a partner.
3) Where do you live?
Omaha (no Microcenter or Frys)
CPU, Motherboard, RAM, Case, Power Supply, Hard Drive (1TB+), DVD Drive, Graphics Card Possibly
None
6) Will you be overclocking?
Probably not
19-22 (not sure on exact resolution)
Within the week
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
USB 3.0 preferred
No (not included in the $350 budget.)
So here's what I'm thinking so far:
$125 - Intel Core i3-2100
$28 - Kingston Technology 4 GB 1333MHz DDR3 Non-ECC CL9 DIMM STD Height 30mm SDRAM KVR1333D3N9H/4G
$65 - Biostar H61MU3 H61 Micro ATX (has USB 3.0)
$60 - Samsung F3 1TB 7200 RPM (Newegg since Amazon isn't nice to hard drives)
$20 - Sony 24X SATA Internal DVD+/-RW Drive AD-7260S-0B - Bulk
$40 - Antec EA-380D
Case Ideas:
$40 - NZXT Source 210 (Black)
$40 - NZXT Source 210 (White)
$36 - NZXT Gamma
$40 - Cooler Master Elite 371 Mid Tower
$40 - Thermaltake V3
Total: $378
So I need to trim it by at least $28. I could get a case with a power supply like this
$60 - Cooler Master RC-310-BKR2 Elite 310 with 420w Power Supply
But I really don't like to do that. I could also look into a Pentium G850
$95 - Intel Pentium G850
I could also go AMD and lightly OC it for him, though it doesn't save any money over the Core i3 2100 unless we use his old DVD burner since this motherboard has an IDE port:
$120 - Phenom II X4 955 Black Edition 3.2GHz
$70 - Biostar A880GU3 (has USB 3.0)
So, thoughts? Have I missed any great deals on Amazon?
None
Probably not
Within the week
USB 3.0 preferred
$40 - Antec EA-380D
Case Ideas:
$36 - NZXT Gamma
Total: $378
