30bits videocard
Mastaba
I' m currently searching for a small videocard able to output 30bits (3*10bits) colors to plug with a futur PA301W for photographic and desktop usage.
I heard 10bits require a displayport and won' t work with DVI.
I don' t need enormous power, but if i can launch old 3D games it would be nice.:)
A very low consumption is required (for energy saving and for silence).
I saw the AMD V3800 which have a displayport and seems to support 10bits, but it seems a little old to me (not latest 28nm)
Ideally a 28nm/zerocore/low power card would be perfect, but i don' t know if such a card exist or is ever planned ?
HDMI 1.3a and above can do deep color too, DVI can theoretically do deeep color, but it's not part of the standard. All the firestream/Quadro cards can, as can a few of the geforce/radeons (the is one I think, some of the 400 series geforces can too (probably the lower end models meant for media play due to blu ray).
http://www.amd.com/us/products/desktop/graphics/7000/7750/Pages/radeon-7750.aspx#2
Well, the workstation products aren't ready on the 28nm front, but as you can see the lowly 7750 that doesn't require any external power does support deep color through hdmi (and i guess through display port). So, pretty much anything of the 7xxx series would have a comparatively low power comsumption while supporting deep color.
If nvidia would put out their mid and low end products too you would be able to see the same thing i bet, as they claim that the support for such features exists in hardware and will be coming in a future driver release of the 680.
If you don't mind using non 28nm tech, as DeathPrincess said a great range of radeon's and geforce's support the feature too, just check for the HDMI version indeed.
