|MaguS| said:Ya, 60C looks high. Im not even breaking 50C at 2.2Ghz at load and Im on stock cooling...
MD said:AS2 and AS3 are optimized for silicone cores and small surfaces like on TB and Barton and PIII. On other hand they are too thick for IHS CPU's like Winchester, Northwood and PIV CPU's. Try to use just normal silicone thermal paste and check out temps just to see is it a AS3 problem. If it comes out AS3 aint good then use AS5 or plain silicone thermal paste.
Though on other hand Zalman 7000ALCU ain't that preformer wither. Idle it's not bad temps but He cant gett rid of load energy. IMO something like XP120 would be much better choice. If You wanna stay with Zalman see 7700cu it preforms much better though doesn't fit on all mainboards.
MD
morfinx said:I think I might have used a bit too much AS3, I just coverd the whole chip with it. Perhaps it's not the best thermal compound for the application, that and it's old. I'll try some AS5 and see if it improves.
Highlife, I'm using a utility from the mobo manufactuer, it reads the temp off of the on die temp sensor.
Major_A said:Here is what the previous poster is describing.
http://www.arcticsilver.com/arctic_silver_instructions_big2.htm
Now I feel like I'm getting my money's worth out of this XP-120. According to Abit's software this thing idles at 35-37 but it never loads over 49(3000+ @ 2.43).
