wyndetygre
- Jan 21, 2009
I'm building a very inexpensive computer which will be a big upgrade for me. It will be used for light gaming, video encoding and normal home use on a wireless lan. I'm hoping to keep the cost in the $300 range. Shipping may cost a little more. (hopefully under 10% to eastern North Carolina)
My original system specs are:
dual boot linux and windows - ubuntu 8.10 and Windows 2000 professional
1 Ghz Athlon CPU
AC97 Audio Controller on motherboard
Radeon Mobility 9600 in AGP 4x slot
Network controller - Broadcom Corporation BCM4306 802.11b/g Wireless LAN Controller pci slot
VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 23)
512 megs ram
western digital 80 gig hard drive
liteon cd reader burner
It won't be that hard to improve on this. I built this system back in 2002. (newer hard drive and video card) I hope to make the new one last at least that long. I had a pIII 300 Mhz that died after thirteen years so I expect longevity.
My tentative picks are:
motherboard - ASRock A780FullDisplayPort AM2+/AM2 AMD 780G Micro ATX AMD 69.99
cpu - AMD Athlon X2 BE-2400 Brisbane 2.3GHz Socket AM2 45W BOX - Retail 49.99
ram - A-DATA 2GB 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) 18.99
power supply - Antec earthwatts EA380 380W ATX12V v2.0 80 PLUS Certified - Retail 34.99
Pioneer 20X DVD±R DVD Burner Black IDE Model DVR-116DBK - OEM 22.99
Undecided or unclear on:
I'm having trouble deciding on a hard drive. I need reliability and low cost.
I'm unclear as to the best value video card. I need low power and quiet. Oblivion is as hard core a my gaming gets for now. It looks like the onboard video might work fine.
After market cooler is up in the air as well. It depends on how loud the cpu fan is on the AMD.
I'll a need a cheap reliable case.
I'll be reusing my 19 inch lcd monitor. (maybe - if the d-sub on the mother board will hook up)
Reuse the broadcom wireless if possible.
Any help on the undecided will be greatly appreciated. Feel free to advise me on my picks as well. I have not kept up with hardware since I no longer work as a computer tech.
1 Ghz Athlon CPU
512 megs ram
