My quest for a good 30" LCD monitor continues. Price doesn't matter that much for me if I get what I want. Here is what I have so far in this segment:
Apple 30": Old school IPS panel and still expensive, not to mention it says apple on it. No joy.
HP's 30". Same screen as the Apple. Not.
I hear good things about the HP's and the Apple monitors are simply overpriced. They are good monitors though.
Gateway XHD3000: Bought one and returned it. Overall good PVA screen with a ton of features. Poor quality control. Blackout issues and big time input lag when not using native resolution. Next.
Right, I've heard about the input lag being horrid on the Gateway XHD3000. I can feel input lag on some monitors even when others can't. This monitor would be a no go for me even for normal use.
Dell 3007: Model's been around for ages, IPS non-wide color gamut. Although acceptable input lag of around 12ms. Overall though, feel the need for something more contemporary.
12ms is NOT the input lag. There is no input lag on the 3007WFP. The response times are 11ms and 14ms depending on certain variables like grey to grey, grey to black etc. You also forgot about the newer 3007WFP-HC. That monitor has better response times and no input lag. The color gamut is also better than the classic 3007WFP.
Dell 3008. IPS screen, wide color with a ton of inputs. Backlight bleeding problems? This LCD has been out for a while now but I still cannot find any input lag numbers. Maybe someone can help with that. This is a promising screen but I cannot purchase one until they solve the backlight bleed problems and I get some numbers on input lag.
Again you are mistaking input lag for response time.
NEC MultiSync LCD3090WQXi. NEC's new top dog soon to be released. It's specs even top the Dell 3008's. IPS screen with wide color and a bunch of professional features. Obviously input lag numbers don't exist. I just might have to bite the bullet and purchase one and put it through some tests. Hopefully I can find a seller with a liberal return policy.
That sounds like a fantastic monitor, but I haven't heard much about it. Good luck finding a seller with a liberal return policy.
Samsung XL30. Sexy hot LED backlight. PVA screen?? Samsung sure does like their PVA's. Even though it's priced about double all other 30"s at about $4500 and not for sale yet, I'd consider it if the input lag was low. I am just wondering if a PVA screen is really worth that much no matter what backlighting it has.
I won't touch PVA monitors. They are often succeptable to input lag and they have horrid color reproduction and the viewing angles aren't the best.
Here is more information on input lag: http://en.wikipedia.org/wiki/Input_lag
Again you should not confuse response time and input lag. They are not the same. Monitors like the Dell 3007WFP and 3007WFP-HC have no input lag due to the fact that they have no hardware scaler.
