It's the bracket itself.Is it only the atx psu that interferes with longer motherboards, or is it the bracket itself? Because if it's the former, you might be able to get that extra length with an adapter to use an sfx psu with the atx bracket.
It moves the PSU pretty far forward, but the actual bracket ends only a little further forward. Maximum motherboard depth is about 203mm with this bracket. There is some room available for the bracket to be shorter, however, so if you were custom making one it could be made to allow for a 205mm deep board.Something like this might help? https://smallformfactor.net/forum/resources/ncase-m1-sfx-l-bracket.5/
It seems to create a lot of space, and counting some pixels in Photoshop it would suggest this board would fit then.
I will wait for dimensions (motherboard size).Heya dudes, sorry if I'm necroposting here,
but I've recently ordered a NCASE M1 (still in shipping) for a z390/9900k ITX build.
However I did notice that the recently leaked photos of the Asus Z390 Maximus XI Gene motherboard may actually fit in the NCASE.
(I know it super early days and the we have no confirmed specs/dimensions).
But looks like it may be a "3 slot" shorter mATX by the looks of it, front panel headers, USB2 and AUDIO headers might be a bit tricky to wire.
Also using a PSU bracket as posted above looks like it would grant just enough space as well width wise but again I'm just speculating at this point.
Would be sweet if I could a motherboard like this in there, the extra x4 slot could allow for 10gbe card or something and the DIMM2 card allows for more m2 drives.
What do you guys reckon?
Heya dudes, sorry if I'm necroposting here, but I've recently ordered a ncase m1 (still in shipping) for a z390/9900k itx build.
However I did notice that the recently leaked photos of the Asus Z390 Maximus XI Gene motherboard may actually fit in the ncase. (I know it super early days and the we have no confirmed specs/dimensions).
FlexATX form factor (Intel 1999):Ncase M1 rev. 3+
Additional motherboard standoffs added for compact mATX boards (226x173mm max w/SFX bracket)
Older Asus ROG Gene: 244mm x 244mm
but New Asus ROG Gene: 226mm x 244mm
170 + 61,5mm = 231,5mm < 244mm wont fit without some PSU Modding.
What about the new ASUS ROG MAXIMUS XI GENE? I know the size will fit as we can see the below dimensions:
mATX Form Factor
9.6 inch x 8.9 inch ( 24.4 cm x 22.6 cm )
https://www.asus.com/Motherboards/ROG-MAXIMUS-XI-GENE/overview/
My main question is will an SFX power supply still fit if we rotated it by a moded bracket somehow onto the front of the case.
There are a couple of ASROCK boards that have Thunderbolt 3 (I think their Z370 and Z390 boards). If you upgraded to one of those you could get Thunderbolt 3 to 10GB network card. I might be doing that asI've been missing my 10gbe card since moving to the Dan Cases itx case so I was searching for the smallest mATX case and stumbled on this thread. It's a bummer that it seems like there isn't anything modern that fits in the ncase m1, if only it was slightly larger!
Another option, is to use a M.2 adapter to pcie x4 adapter and use a normal 10GB network card in the bottom slot.
I will be doing one of these options as I am needing 10GB networking moving forward as well. That is also why i was looking at the ASUS Maximus XI Gene above. Which will fit in height wise but its only about 1mm too wide if putting the sfx power supply off of the front of the case. Its about 1mm too much from what i can see but I might try this soon and post the results..
Wow! I didn't expect this to fit
Wow! I didn't expect this to fitI wonder what cooler you plan to pair with it?
huntk So what's the word on the mATX M1?
I saw the imgr posts, but no build log. How'd it go? Did I read correctly that you mounted the PSU directly to the frame with one screw?
What did you end up doing with the extra PCIe lanes?
