Interesting use of the tube holes
Can we have some pics of the inside?
Not so glamorous, but here are some pics of the inside.
https://docs.google.com/spreadsheet...mJWMjZYSXJvNWNOVzJkdkJPTWc&usp=sharing#gid=26
We got a nice selection here =)
Please add the Asrock Z97M Anniversary and the Gigabyte Z97M-DS3H to the list.
I can't edit the sheet or else I would.
Nice info about motherboard with 3 slot, I find nice gigabyte b85m Gaming 3 motherboard for cheap and wonder is there any other case offer with 3 slot fit that kind motherboard for cheap? So far I think CM Elite 110 case will fit this kind motherboard but only 2 slot.
Unfortunately I don't think so! I think the 3 size is something that's unique with the M1.
Find other case w 3 slot from Hong Kong here
Those will also fit normal 4 slot ATX motherboards, right? (with the fourth slot being unusable of course)
Gigabyte has also "jumped" into the 3-slot mATX/FlexATX form factor with H110 chipset.
These motherboard should fit the NCASE !
Intel has always designed the H61, H81, and H110 PCH for usage on entry-level motherboards.cltang said:I guess these are meant to be entry level low cost boards; from the photo, there's only 2 memory slots like ITX, and not even additional PCI-E x1 slots to use.
From a feature perspective, disregarding cost, there's no reason to use these mATX boards over current Skylake ITX offerings.
Asrock offers a series of 3-slot H110 desktop boards, but no measurements.
IF Asrock is such a great company,
why can't they publish the dimensions (measurements) of their 3-slot Flex desktop boards?
H110M-GL/D3 3-slot desktop board (Fit?, no measurements in manuals or spec sheet)
http://www.asrock.com/mb/Intel/H110M-GLD3/
Sorry for necro'ing this thread, but I hope this is relevant. I came across two 4-DIMM 3-slot Z97 boards:
ASRock Z97 Anniversary: http://www.asrock.com/mb/Intel/Z97M Anniversary/
Gigabyte Z97M-DS3H: http://www.gigabyte.us/products/product-page.aspx?pid=4964
I have yet to find the dimensions for the ASRock board, but it appears to be the same exact size as the Gigabyte board, which is spec'd at 193mm x 226mm. The 193mm width rules out the SFX bracket, but switching to the ATX bracket should yield at least 20mm, if not more.
Component selection on both boards leaves quite a bit to be desired, but there aren't many options for 3 PCIe slots, 4 DIMM slots, and OC support (no matter how mild) in the M1.
Thoughts?
It means you could use that board - the ASRock Z97M Anniversary - in the M1, with the limitation vipz mentioned (must use the ATX bracket instead of the SFX bracket). The ASRock Z97 (non-M) Anniversary is an ATX board, which obviously won't fit.Does this mean I could use a ASRock Z97 Anniversary in a mini itx case?
Hi everyone!
Just registered on the forum. I've been reading this thread and there is a lot of great information on it. I'm essentially trying to find information on a SSF build I plan on doing in the upcoming months, and have narrowed my choices to either a Dan A4 case or this Ncase M1. The computer will be made for VR (likely HTC Vive) - I want to carry it around for demos and the likes easily, and it needs to pack a punch.
While the Dan A4 is great, I'd like to be also be able to add in my current video capture card (PEXHDCAP). It's currently in use with my main desktop, but I plan to sell its guts (and the FX8320 is limiting for realtime h264 encoding of even SCART RGB captures). This is where the M1 might shine: it would allow me to maybe throw in this card in addition to a powerful GPU and CPU, but also spacious hard drive(s) providing a SFX PSU can still fit in.
This thread has a lot of motherboard recommendations, but unfortunately it's not up to date (little information about Intel Gen 6 motherboards) and the Google Doc link is apparently broken.
So I'm now looking for a mystical unicorn, and would love to have some help/feedback with it. The general idea would be to find a compact motherboard that would fit in this case and
- has at least 2 USB3 ports, driven by a microcontroller compatible with a Rift (see: Rift compatibility tool)
- has a 1151 socket (for a i5-6600 or better)
- has one PCIe x16 connector for a dual-slot GPU (GTX970 or similar, or Pascal later on)
- has one PCIe x1 connector for the additional capture card
- allows for a SFX PSU to be used so the 3.5" HDD side bracket can still fit
At this moment I couldn't find anything. Going the Intel 1150 route wouldn't bother me that much, but it's very likely that a higher number of these motherboards wouldn't pass the Oculus tool test regarding USB3 port compatibility. Any idea?
Try this link.This thread has a lot of motherboard recommendations, but unfortunately it's not up to date (little information about Intel Gen 6 motherboards) and the Google Doc link is apparently broken.
MSI has these two:
http://us.msi.com/product/motherboard/H110M-PRO-D.html
http://us.msi.com/product/motherboard/B150M-PRO-VD.html
However, I couldn't find exact dimensions on them so you may want to email MSI and find out.
It's probably slightly too tall, since 22.6cm motherboards practically touch the floor of the chassis. It's also too deep to be used with the SFX bracket (have to use the ATX bracket instead).Would this Supermicro | Products | Motherboards | Xeon® Boards | X10SDV-7TP8F baby fit? 22.86cm x 18.42cm, 16 cores, 128GB RAM, good gracious!
The case isn't really deep enough for it. There's not enough room between the board and the inside of the chassis for the PSU, so it could only be done by having about 10mm of the PSU overhanging the front of the board. It would cut into the motherboard height keepout zone by about 20mm, which doesn't leave much room for e.g. the 24 pin power connector.You might even be able to fit a standard width, short length mATX if you use a SFX PSU, but orient it like an ATX sideways. Mounting would be interesting, but theoretically an adapter bracket from ATX to SFX should work.
