3 new E-mu cards
jebo_4jc
[H]ard|DCer of the Month - April 2011
3 new E-mu
http://www.dailytech.com/article.aspx?newsid=3827
Creative Labs has launched three new E-MU professional sound cards. The new E-MU 1212M PCI, 1616 PCI and 1616M PCI are targeted towards creative musicians seeking multiple input/outputs, ASIO and high quality DACs and ADCs. At the lower end of the new E-MU product lineup is the 1212M PCI. It features 24-bit/192 KHz DAC and ADCs with a 120dB signal-to-noise-ratio. Audio I/O capabilities include 12 input and 12 outputs with MIDI I/O and Firewire. Two ¼” balanced inputs are also available too.
The E-MU 1212M PCI features:
  • Mastering grade 24-bit/192kHz converters - the same A/D converters used in Digidesign's flagship ProTools HD 192 I/O Interface delivering an amazing 120dB signal-to-noise ratio
  • Hardware-accelerated effects - over 600 standalone and E-MU Power FX VST plug-in effects with no CPU overhead
  • PatchMix DSP zero-latency hardware mixing and monitoring - with super-flexible patchbay - no external mixer needed
  • Comprehensive analog and digital I/O plus MIDI - 12 inputs and 12 outputs, plus MIDI I/O and FireWire port
  • Compatibility with most popular audio/sequencer applications - ultra-low latency 24-bit/192kHz ASIO 2.0 and Stereo WDM drivers
  • E-MU Production Tools Software Bundle - includes Cakewalk SONAR LE, Steinberg Cubase LE and Wavelab Lite, Ableton Live Lite 4 for E-MU, IK Multimedia AmpliTube LE and T-RackS EQ, Minnetonka diskWelder BRONZE, SFX Machine LT, plus E-MU's Proteus X LE Desktop Sound Module - everything you need to create, record, edit, master and burn is in the box
Next up is the E-MU 1616 PCI and has an external breakout box. It features 24-bit/192 KHz DAC and ADCs with a 112dB signal-to-noise ratio. There’s also a robust amount of input and output options including two ultra-low noise microphone/line-in preamps, four 1/4” balanced inputs, six ¼” balanced outputs, turntable input, S/PDIF, two sets of MIDI in/out, stereo 1/8” speaker outputs and a stereo headphone output. The stereo 1/8” speaker outputs can be configured for stereo or 5.1 channel audio usage. Lastly is the E-MU 1616M PCI, which is very similar to the 1616 PCI with the exception of the DAC and ADCs. The E-MU 1616M PCI has higher quality DAC and ADCs with a signal-to-noise ratio of 120dB. Aside from that its virtually identical to the E-MU 1616 PCI.
The E-MU 1616 PCI features:
  • Premium 24-bit/192kHz converters - 112dB signal-to-noise ratio for pristine recording and playback of your tracks
  • PatchMix™ DSP zero-latency hardware mixing and monitoring - with super-flexible patchbay - no external mixer needed
  • Two E-MU XTC™ Class-A, ultra-low noise preamps (-127dBu) - Mic/Line and true Hi-Z inputs via Neutrik connectors, with analog soft limiter, 48V phantom power and 60dB of gain
  • Compatibility with most popular audio/sequencer applications - ultra-low latency 24-bit/192kHz ASIO2, WDM and 64-bit drivers
The new E-MU cards are priced at $150, $350 and $450 for the 1212M PCI, 1616 PCI and 1616M PCI respectively.
Seems like there is no direct upgrade for the 0404, unless they are just trying to bring the 1212M into the 0404 price bracket. Isn't the 1212M a dual card solution?
I don't see the difference between the old E-MU 1212M and this "new" E-MU 1212M PCI.
Anyone have any insight into this?
(My thought is the article botched up)
