$3,500 Budget, read on.
PeteH
While I -can- spend $3,500, I'd obviously not like to spend that much on a computer. When I buy a computer I like to make sure it will last me for 3 to 4 years worth of gaming. My current computer just broke the 3 year mark and It's starting to show. Now, I haven't built a computer in 6 years so I'm a bit rusty.
Ideally I'd like to spend just under $3,000, but as said above I can go as high as $3,500. I'm looking for SLI'd Nvidias, probably a quad core processor, a motherboard that will support future upgrades. All that good stuff. I was thinking of doing 2 Geforce 9800's, 4 gigs of DDR2 1066 ram, maybe an intel q9450. I have no clue about fans or thermal grease. Can anyone post a great build for my budget that will last for the 3-4 years I'd like?
Thanks in advance. :)
my signature cost me almost $3000 even.
its fast as all hell for gaming. maxes everything out. (sans crysis, but does 1920x1200 at very high) im overclocked from 2.6 to 3.0 with great temps.
for the future, when its no longer 'new': (2 years?)
-overclock from 3.0 to 3.6-4.0 with some beefier fans. maybe w/c...
-pick up a second 9800gx2 which should be nice and cheap by then.
im sure you'll differ on some parts, most are personal taste... (q6600 vs q6700, display, etc) but the board/cpu/gpu combo is GREAT. i couldn't be happier, and i know there is much room to expan/overclock.
my opinion on what you mentioned:
why go sli now? you'll take up both slots and be forced to buy new card in sooner time.
thats why i got a 9800gx2, so it only occupies one slot. once it drops in price, i'll grab a second and be kicking ass again.
q9450 is good, but i'd stick to a q6600/q6700.
thermal grease/fans is cake. read the stick in overclocking/cooling and you'll know all you need to know.
a 9800gx2? Aren't those the 1 gig versions? Seems a bit overkill, no?
well, figure its right around the same speed and price as dual 9800gtx's.
they take up 2 slots though.
if you want this to be good for the future,
get a gx2 versus 2 gtx's, that way you'll have a second slot open for the future expansion of your machine.
another way to say it:
i rather buy a second 9800gx2 in 2 years to match the one i have now... than have to replace two 9800gtx's for whatever is a moderately priced card in two years.
Or maybe just splurge on 2 now so I can brag and be an internet cool guy =P
I'm not sure why so many people expect to be able to build a computer that will let them play all the newest games at high settings for 3-4 years. That's an absolute eternity in computing terms. Not that it's impossible, but even if you build a bleeding edge system today, you'd still start to notice significant drop off after the first year or two.
IMHO, a much better strategy is to build a mid-high end system every 1-2 years. Case and PSU can be recycled usually, sometimes even things like the MB and HD as well.
For instance, you could build a rig today that'll play any game at high to max settings for the next 1-2 years for 1000-1400 dollars (instead of a money-wasting $3500 system that'll be underperforming in 2 years or less). In 1-2 years, build again for that amount. That way you'll always have a great setup that gives you great value for the dollars you spend.
The other problem with trying to build something today you'll be very happy with in 2 years is Nehalem. This next gen intel CPU will come out at the end of '08 and will require a new MB (different socket). It'll crush the current C2D chips.
A good read: http://www.hardforum.com/showthread.php?t=1312483
If you build it yourself, you'd have to really try hard to even spend close to $3,000, although I suppose two $600 videos card will help with that, hehe.
Case: Antec Performance One P182 SE or Coolermaster Cosmos S if you want a window
PSU: Corsair CMPSU-1000HX
CPU: Intel Q9450
Motherboard: eVGA 750i SLI FTW
RAM: 4GB (2 x 2GB) OCZ Reaper HPC 1066MHz
Cooling: ThermalRight Ultra-120 Extreme w/ Scythe S-Flex 120mm fan
Video cards: see below
HDD 1: 300GB WD VelociRaptor
HDD 2: 640GB WD Caviar SE 16
Optical Drive: Samsung S203B or S203N (w/ Lightscribe)
Case Fans: Yate Loon D12SL-12
Next generation video cards are being released in a few weeks. nVidia's on June 18, ATI's on Jun 23. Some of these cards will beat the 9800 GTX's, so I suggest waiting since it's not that far off. Also, unless you will be gaming at 1920 x 1200 or better, SLI won't be necessary.
There ya go :) You can google those parts for best pricing.
Solid advice here. Also OP, consider waiting for the new geforce cards coming out. And overkill (aka waste of $$) would be TRI/QUAD SLI, one 9800gx2 is hardly overkill.
Yes, I own a 24'' monitor and it runs at 1920x1200. Currently I'm running a single 7800 GTX 256mb and it's doing great. Can't imagine what SLI'd next gen card will be like. :D
CPU: Intel Q9450
One: I'd never buy a Raptor, even a Velociraptor. Reduced loading times, to me, aren't worth a 3x+ price hike over a very fast 7200RPM drive. There's a measure of personal preference there, but I just want it clear -- it does nothing for gaming performance, only reduces loading times, and we're talking about a few seconds. Nothing life changing.
Two: Much like the Raptor, the Thermalright Ultra 120 Extreme's day has come and gone; unless you're willing to lap your HSF and processor both, look to the Xigmatech S1283 or ZeroTherm Nirvana NV120 instead.
Three: A 1000HX? Unless you're considering Tri or Quad SLI, forget it. A TX 750 (for less than 1/2 the price) will give you plenty of power. My machine (X3220 quad @ 3.6Ghz, 2x 8800 GTX @ 675 core / 1620 shader / 1000 memory, 2 HDDs, 2 DVDRWs, 8 120mm fans, and Laing D5 vario and Laing DCC 3.1 pumps) only pulls ~600 watts at the wall under full load -- 3DMark 06 1920x1200 8xAA/16xAF loop, plus Prime 95 Small FFTs -- so assuming 80% efficiency, that's 480 watts internal draw. A quality 750 watt PSU is plenty for most modern systems, even heavily overclocked.
Everything else I agree with, generally, though I'd drop the 750i FTW in a heart beat (best SLI board out there right now, but still an Nvidia chipset; avoid it if you can) for a P35 or P45 based board if the new cards prove fast enough that SLI isn't a concern at 1920x1200 anymore.
Now, it's said there is a problem with the eVGA Nvidia nForce 780i mobo. At the moment I don't think I'll need to SLI if I get a 9800gx2. In the future, I might. That or buy a new mobo. Would said motherboard be acceptable?
One: ... Three:
I was just trying to help him spend $3000 :)
I was not aware of this. I will make the appropriate changes in my notes. I haven't seen this changed in the "recommended coolers" cut-n-paste, and thought it was still the best to get.
If the OP insists on SLI, then that's the motherboard he should get, so I listed it. Even if he doesn't SLI, it's still a great board for overclocking. Even [H] gave it a great review.
The 780i? I would not recommend a 780i. I own one -- an XFX branded reference board, same as the EVGA except for the BIOS, same hardware -- and have had no problems with it, but some have. The 780i is pretty much a revision of the 680i with a bridge chip to add PCIe 2.0 support. As a result you run the risk of inheriting from the slew of issues with the 680i chipset.
The 750i on the other hand seems to be completely new silicon, and the EVGA 750i FTW gives you a pair of 16x PCIe 2.0 slots without the issues with the 780i. The only problem is, you only get 4 SATA ports; of course, SATA controller cards are not very expensive, should you find you need more. Plus, it has all solid capacitors unlike the reference boards, which is nice.
All that said, if you can avoid SLI (and thusly, Nvidia chipset motherboards) do so. SLI as an upgrade path is a horrible plan. You will almost always be better served by selling your old card and buying a newer, faster single card, rather than buying another of the older card for SLI. This is partly because by the time you "need" a second card it is likely to be EOL, or "end of life" and retailers will stop dropping the price on it, if they carry it at all (look at what some retailers want for an X850 Crossfire card, for an example of price craziness). Also, two of the older card are likely to be slower in most titles than a single newer card anyway, due to improvements in shader language and other tweaks to newer architectures.
Plus, Nvidia chipsets can be very troublesome. I've been through enough (5+ 680i variants, and now the 780i reference board) to know.
Alright guys, I think I have all the information I need. I greatly appreciate all the help and will be sure to stick around on these forums for years to come. Glad I found them.
I concur with silent-circuit.
Also, wait for new ATI and Nvidia cards to come out in a few more weeks. It looks they'll outperform the 9800GX2.
I agree with Danny.
QFT.
Its still included in my list for completeness, as is the Noctua. The wording prefacing the list usually recommends the two silent mentioned. I guess I could drop it from my list, but whatever, lol.
Same here. Though I should probably remove the Ninja as well since Xigamatek S1283 is about the same price and needs a bolt-thru kit as well.
go with the 750i ftw, the only problem they have is a raid one, but a bios update will fix it.
I think the ninja is still best for passive cooling or low airflow systems, though, due to its more spread out fins.
