HardOCP News
[H] News
- Dec 31, 1969
Remember that guy awhile back that hid his office with a couple used bookshelves and four dollars worth of hinges (here)? Someone knocked off his idea and they are charging $3,000 for it.
It's not really a knockoff of that guy. James Bond has been doing it since the 60s.
BTW, whats the point of investing time in this if you end up showing it off on the internet, lol!
True, true. My point is that the first guy did it for a couple bucks (so can you) and these guys want $3k.
Would only be worth it if you had a $10k desk in the hidden room.
Dude, so true...so true.
A couple of bucks for the hinges, compared to $3000 for a solid wood bookcase plus hinges.![]()
From the looks of it it, it doesn't touch the floor. There's also a viable gap at the top.
For 3000 USD I expect something that'll keep Holmes busy for more then three seconds.
I wouldn't want a solid wood bookcase. If its solid, where inside would there be open space in which to put books or shelves? It'd just be a big block of wood.
You don't need to put the books (or shelves) inside the wood. You simply put the books on top of the horizontal planks of solid wood (shelves), like in the picture. Dont try to put the books on the vertical planks of solid wood either.
Have you heard of the expression: As thick as two short planks?
It's only cool if you have to pull on a book and it automatically slides/swings open.![]()
Proper solid-wood furniture is *expensive*. Building something out of real plywood is expensive, it's even more expensive if it's cabinet grade plywood, and if you go for solid wood, it's even more. And that's just the materials cost for the wood. There's a lot of labor that goes into building it, and properly finishing it is a very time-consuming task.
/says the guy who has built some of his own furniture and hates the staining/varnishing stage
