2x quad core motherboard?
HAF72
1337 :)
I was wondering if there were any motherboards that supports 2 intel quad core cpu. Thanks!
Might be building a computer with 2 quad cores :)
:eek: :p :D Forgot that there were xeon quad core too :)
errr how well are the quad core (xeon) for gaming and I can run vista with with them right?
Most people have loyalty to performance, not a brand when it comes to processors.
I remember the days when all anyone talked about really on Hardocp was AMD performance and how it blew away Intel.
Today, it's Intel.
With that said, forget about going Intel Dual Quad Core for now and lets see what AMD has around the corner.
From what I understand from my research, the new AMD stuff is supposed to be 40% - 50% faster than Intel's current CPU tech. I am no expert and could have a fact or two wrong.
I would love to own a Dual Quad, 8GIG ram setup w/ Windows Vista 64bit Premium.
Of course, if it's AMD who has the more powerful CPU, then my setup would be AMD.
I just built a new Intel Quad Core rig, I love it.
From what I saw that's in floating point performance, not integer performance (Integer numbers not released which probably means that there isn't anything to write home about). So it depends on the programs you're using ;).
your right, maybe just build a quad core , 680i, dx10 right now and see what amd has to offer, maybe they are pretending that they are in bad shape and that intel will be in the lead for a long time and then amd releasing something that pwns intel cpus. Well I hope so, so then intel will make something better and faster :) and amd and intel....
If you are building this for gaming you need to be looking at board compability for your video solution and determine if the games you want to play even make much use of multi-cores. Many games dont have address extension so even though you have 20gb of ram they wont ever use it well.
Go quadcore , 680i you wont be disappointed.
They don't.
True enough.
If you're thinking of getting a quad or dual quad system mostly for gaming - save your money and wait for future games that will actually utilize multiple CPUs. Right now there is Quake 4 and maybe a couple others, but that's it. Alan Wake will probably require at least a dual core or two CPU system from what I've been seeing.
Save money for when you will need quad cores, and by that time you'll have cheaper and newer CPUs, hopefully.
Thanks guys! Yup, looks like maybe just a 680i motherboard, quad core and 8800gtx :) for now.
If you want to go gaming, dont go xeon or dual quads or anything like that.... the 680i plus quad should work out fine.
