2nd card in SLI pair undervolting?
Discussion in 'nVidia Flavor' started by Evil Scooter, Jun 10, 2018.
  1. Evil Scooter
    Evil Scooter [H]ard|Gawd
    1,830
    Sep 22, 2000
    Both my 1080ti's are under water. Getting some decent clocks outta them.. constant 2k GPU and 5800 on the memory. Both cards run under 40c full load. Oddity is that card 1 runs at 1.093v and the second only hits 0.981. The clocks match. Is this common?
  2. Master_shake_
    Master_shake_ Little Bitch
    7,114
    Apr 9, 2012
    One chip is better than The other.
    The one with lower voltage is more efficient.
  3. auntjemima
    auntjemima [H]ardness Supreme
    4,149
    Mar 1, 2014
    I don't see an issue. Not all cards are made the same. Secondly, which card has a higher voltage, the first or second card in the loop?
  4. Evil Scooter
    1,830
    Sep 22, 2000
    Not an issue.. both cards run fine.. just an oddity. I thought using AB linked matched everything on both cards.. ie. volts and clocks. The second card in the loop is vising the higher volts.. though both stay really cool under load.
  5. Spartacus09
    Spartacus09 Limp Gawd
    466
    Apr 21, 2018
    Could theoretically be a sensor malfunction/variation too, but as mentioned not much concern.
  6. Evil Scooter
    1,830
    Sep 22, 2000
    Only thing that "worries" me is a seemingly low OC for cards that run in the 30c range under load. When I attempt over 2K on the gpu video freezes... with one GPU reporting under 1v I was thinking that might be why.
