- Jun 7, 2007
It'd still be flowing in the cpu loop...unless he has the pumps supplying the loops individually? But didn't sound like that.I'm not sure this would be a good idea. Most internal PC power connectors aren't designed for hot swapping, so you'd run a risk unplugging the water pumps on the loops being modified; and unless you've got T connectors with unused ends breaking the loop to change connections around would leave the pump running but unable to move water which isn't good for it either.
